Any help? Tryign to take off the bumper
Old Sep 8, 2006 | 10:40 AM
asianbandit's Avatar
Hey everyone...I am planning on taking off the bumper so I can re-paint it. This is something I have never done, any advise on the best way to take it off and the type of paint to use to get it back to about the same color?
Here are some pictures that i took of the damage...as you can see it goes all the way across, guess the person before had a fender bender.
http://www.utmem.edu/~szada/DSCN1042.JPG
Old Sep 8, 2006 | 11:15 AM
Dubbya's Avatar
VK56 Inside
REMOVAL — Front bumper assembly
1)
Remove bolts securing engine undercover from the front side.
2)Remove bolts, screws and clips securing fender protectors in the wheelhouse. Then remove left and right
fender protectors.
3)Remove clip securing grille and remove the grille.
4)Remove screws securing left and right side combination lamps and remove the lamps.
5)Insert flat-bladed screwdriver between side marker lamps and turn signal lamps. Then remove side marker
lamps.
6)Remove screws securing left and right turn signal lamps and remove the lamps.
7)Remove the clip securing fog lamp finisher and remove the finisher. Then remove the bolts securing fog
8)Remove nuts and bolts securing headlamps. Then remove left and right headlamps.
9)Remove bolts securing both bumper side brackets and remove the brackets.
10)Remove bolts and clips securing bumper fascia.
11) Remove nuts securing fascia from both bumper sides. Then pull bumper fascia out.
12)Remove nuts and bolts securing retainer from center and both sides and remove retainer.
13)Remove nuts securing bumper reinforcement and remove the reinforcement.
14)Remove bolts and nuts securing bumper stay and remove the bumper stay.
Calabar
Oct 5, 2015 09:57 PM
ricky7780
Sep 24, 2015 06:50 PM
Max8
Sep 22, 2015 02:53 PM
