Electical problems, IMMU and elect. harness questions!! HELP!!!
Old Sep 9, 2006 | 10:28 PM
Nick7455's Avatar
Ok guys this is a long complicated one. So last year I wasn't able to start my car and was told it was my fuel pump from a small local shop. I replaced the pump and the car worked for about a day and then same thing...no start. So I take it into the dealer and they say it needs a new IMMU system because somehow it went bad. I paid around $800-900 to replace the system.
Right after I got it back I had some similar problems with starting, I would have to turn the key multiple times and then it would work.....now this was on a off but was pretty random.
Then about 3 weeks ago I had the same issue with a no start. I checked everything and then got it towed. Nissan again diagnosed it with a bad IMMU as well as an electrical code string. So they again replaced the IMMU but under warranty. So I get the car home. Go out one time to the bank and then back. Go to start it for work about an hour later and the same problem. So I tow it back to Nissan and they have it for about 2 weeks diagnosing it as some electrical problem. I went down to the dealership Friday and they say it's my electrical harness and that it has too much resistance going through it and it is frying the IMMU and supposidly the ECU as well. They quote me about $5000 and say basically the car is a total loss. They say both wiring harnesses must be replaced as well as the ECU and IMMU system. Here is my question however:
I did put some after market mods on the car but it was minimal and quite a while back. I had done the fog light rewire, blinker mirror lights, speakers, and new headlight harnesses. Would any of this "decay" or cause significant irreverasble damage to the wiring harness? How would I go about fixing this by myself? If in fact the IMMU is dead again couldn't I just remove the IMMU unit and possibly get a used 98 ECU that wouldn't prevent the car from starting without IMMU codes? What is the best possible course of action aside from parting the car out or taking it as a total loss?
I really need a TON of help here from anyone that can help. Thanks!
Old Sep 10, 2006 | 06:07 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
5000 bucks ? theyve lost their cans this time.....! LOL
too much resistance thru the harness ? hummm
if you dont have the cash to get a new ride if it was mei would check all the grounds on the harness and make sure they are making a good connection. take a brief look at the harness and make sure its not kinked broken or bent anywhere especially by the ecu. try a used ecu you can get it cheap for like 50-100 bucks and if the immu is cooked grab that off the parts car too. change everything and see what happens. if the cel comes on pull the codes manually and let us know whats up...btw if ya come across a 99 cali spec 5spd non traction control max in the boneyard pull the ecu for me i need one !
Old Sep 10, 2006 | 09:42 AM
Nick7455's Avatar
Here is the thing though....even if I do all of that I still have to get the codes into the ECu in order to start the car which means taking it to nissan and dropping around $100 to reprogram keys and it might be all for naught....
ah2002
Mar 9, 2016 01:42 PM
JMag90
Aug 25, 2015 09:17 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
