Hey..just got my intake off ebay..
Old Sep 10, 2006 | 08:09 AM
Fre$h_TurK
i got this one http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
- what are these cheap blue plastic things? ...
-and the hoses' heads are bigger than the holes on the middle pipe... is that ok?...or am i better off with using the stock hoses and all.?
- there's nothing that i'm missing right ?
Old Sep 10, 2006 | 08:17 AM
Neo Raven456's Avatar
You don't know what to do with it? ... put it in
Old Sep 10, 2006 | 08:33 AM
EnervinE's Avatar
i has college
Never buy something you don't know how to install...
Old Sep 10, 2006 | 08:38 AM
Fre$h_TurK
gtfo ahole....i dont gotta ask u what to do
Gismo-T's Avatar
B!tch We Got a Problem
No instructions?
Why are you buying things you don't even know how to install?
Do you even know what it will or won't do?
Fre$h_TurK
i do... i needed some instructions..
"put it in" ....stfu
Old Sep 10, 2006 | 08:39 AM
Fre$h_TurK
Originally Posted by Geo T
No instructions?
no instructions...... i know what to do with it but im asking some questions
Old Sep 10, 2006 | 08:42 AM
Gismo-T's Avatar
Relax,
Check the How to's, & you'll find out or look at some pics
Old Sep 10, 2006 | 08:48 AM
99se5speed's Avatar
SHIFT_up
So much drama on the org....
Anyway Turk i know your very far from having a Injen intake but this should still help you in changing yours since your e-bay one is probably a replica...This how-to is for the 5th gen but you should be fine.
http://www.vqpower.com/v2/modules.ph...showpage&pid=9
Old Sep 10, 2006 | 08:57 AM
99grnmaxgxe's Avatar
Sorry to tell you this, but you bought one of the "wrong" intakes. It's "wrong" b/c it has 4 nipples coming out of the pipe, it's only suppose to have 3. You can just cap one of the little ones off and you would be okay.
Old Sep 10, 2006 | 09:10 AM
UkiSash's Avatar
I agree.
and Dang dude no need to snap just trying to help das all if you didnt want anyone saying anything shouldnt have posted. Reguardless no need for instructions just take your stock one off and see where everything goes take pictures if you need to. It reletively easy just use your imagination.
Old Sep 10, 2006 | 09:17 AM
SMX95's Avatar
Shut the **** up MAN!
you have ZERO knowledge in the automotive world. If you had any common sense you would know NOT to use those hoses for the intake. INTAKE = AIR
ENGINE is nothing but a big vac. THEREFORE those condom like hoses arent going to go jack. For a working boy you shouldn't need to buy crap from ebay. You spend the money and do it right the 1st time.
Old Sep 10, 2006 | 09:55 AM
95turbo gxe's Avatar
Well From what I can see your not going to make it long on the ORG. Why the childest remarks? Search talk to people and you can get help and figure out how to do things on your on. On the intake why does the blue things got to be cheap? Those couplers will do just fine for the intake.
Old Sep 10, 2006 | 10:21 AM
Turks, I understand why you are frustrated, they are giving you BS replies so you do like wise. I'll try to help you as much as I can:
Take out the four bolts holding the MAF to the upper portion of the airbox with a 10mm wrench. With the upper portion out, take the stock air filter out and you should see 3 bolts holding it the bottom airbox. Take these out with a 10mm socket. Then you should be able to pull out the MAF, be very gentle and carefull. Unclamp the two big hoses and take them off the stock midpipe, you can gently pull out that little hose. Now unscrew the clamp holding the midpipe to the throttle body. Now put the blue coupler into the TB, put the new midpipe in the other end. Plug in the 3 hoses, use the other coupler to connect the pipe with the MAF. Bolt the MAF adapter to the MAF and install the filter. Hope this helps.
Old Sep 10, 2006 | 10:28 AM
This was pretty helpful b/c it has pics: http://www.brianv.net/mods/filter/
Old Sep 10, 2006 | 12:33 PM
SMX95's Avatar
^ LOL ROFL OMG
Duck tape FTW??????? OMGZORS!
I assume you haven't read any of his other threads. Anyway yeah go ahead do it that way duck tape the bracket because you need to make it air tight. You should use black tape therefore it wouldn't look as stupid as it does....
Old Sep 10, 2006 | 12:43 PM
I hope you aren't thinking that that link was mines. I got it from the Stickies.
Old Sep 10, 2006 | 01:36 PM
d00df00d's Avatar
Old enuf to pick his own gears
1. Use whichever hoses fit best, and use the clamps from your stock hoses to hold them onto the nipples on the midpipe.
2. Cheap couplers (the blue things) are not the best things to have, but they'll work fine. Just don't manhandle them, don't spray strong solvents (like brake cleaner) on them a lot, and check them for cracking or leaks every couple of months.
3. I could be wrong, but it doesn't look like there's anywhere to screw in your IAT sensor (currently fastened to your airbox with 2 screws). If that's the case, no big deal. Just tie it up out of the way and tuck it in somewhere near the filter.
4. Be prepared for some slight losses in torque and throttle response at certain RPMs. Intakes don't do much on these cars without tuning.
Old Sep 10, 2006 | 01:43 PM
For the IAT sensor, just leave your snorkel on and you won't have to worry about it.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
