fuel leak near the tank
Old Sep 11, 2006 | 02:57 PM
seanish4042
last week i was filling up....and just farting around waiting for the tank to fill.
so i hear the click, like its full. then i see gas coming out from under my car. i was like wtf. so i look and it seems to be leaking from a hose right in front of the tank.
a few weeks back i took my pump out to check it, and put it back in. that doesnt seem like it would cause a leak tho. then for the next like 4 days it would smell real gassy on start up. my milage has suffered considerably.
any ideas?
Old Sep 11, 2006 | 03:17 PM
babymac's Avatar
BOOST 4 LIFE!
I had a very similar problem , but it was the small black hose. It ended up being cracked so it was leaking so I cut a little off(the part that was cracked ) and all fixed. I would check to make sure that there aren't any cracks or holes.
Old Sep 11, 2006 | 05:09 PM
SuperChris's Avatar
Infiniti 35 Double G's
ah...had my fuel pump changed 3 months ago because i thought it was toast (problem turned out to be something else), and at the time, the mechanic who flipped it out said the rubber seal around the top of the pump (under the back seat) was about worn out. sure enough, a week later, much like u describe, filling up at the gas station, pump clicks "full", and there's a massive puddle under the rear wheel.
long story short, it's likely the gasket that fits around the top of the fuel pump, just under the metal plate that covers it (under the backseat). be VERY careful asking for the correct part at a dealer...should cost no more than $8-$10, and it is VERY thin, like a shoelace. make sure they don't give u the wrong thing...i had to go back to get the right one after they gave me one that was wide/thick.
try that...it's a cheap & easy fix.
Old Sep 14, 2006 | 10:29 AM
seanish4042
i had a lot of trouble getting that gasket back in. but why would that cause a leak OUTSIDE of the car? it was leaking from a house on the undercarriage right near the outside of the tank.
its not like there was gas leaking into the back seat.
Old Sep 14, 2006 | 08:22 PM
jasonv's Avatar
it could be the fill tube thats messed up. did you have to drop the tank to do your pump?
Old Sep 16, 2006 | 04:51 PM
SuperChris's Avatar
there wouldn't be a leak in the backseat...you'd certainly smell the gas, and it may also appear to be leaking directly from the hose under the car; trust me, it's coming from the top of the tank (fuel pump gasket). and yes, the gasket is a minor PITA to re-place.
if there's still evidence of a fuel leak, at least it didn't cost you $100 to rule out the gasket (shoulda been <$15).
Old Sep 16, 2006 | 04:53 PM
SuperChris's Avatar
no, u don't have to drop the tank to replace the pump. u also make a minor good point: check & make sure the two supply hoses on top of the fuel pump are secured tightly...that's also a possible leak source.
Old Jan 10, 2007 | 06:50 PM
kbmaxima's Avatar
bumped a pretty old thread, but I'm tracking down a fuel leak as well which pretty much decides if i sell the car or not. I checked the gasket under the backseat and it was fine, no gas, two hoses were fine, dry. was it that new gasket that remedied the problem? how is it now that it's much colder and 3 months
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
ef9
Oct 4, 2015 08:43 AM
