Starting problem??
Old Sep 13, 2006 | 03:36 PM
babymac's Avatar
BOOST 4 LIFE!
Starting problem??
I know this has been discussed a million times but, I searched and tried everything there is to try.
This is what happens when the car is sitting for 5 or more hours(doesn't matter temp) it cranks for like 10-12 seconds stumbles a little ad then starts. I tried alot of things including cleaning the throttle body,iacv,pvc,changing fuel filter, ergc selenoid valve, and the satarter was replaced right before i bought it and many other things. I have no check engine light or any other problems.The only thing I can think of now would be the fuel pump, but would that affect the overall performance of the car?? I am hoping some of you max guru's can help me out.
Old Sep 13, 2006 | 03:48 PM
Muyrec's Avatar
Checked the battery?
Old Sep 13, 2006 | 06:33 PM
jasonv's Avatar
plugs and wires
Old Sep 13, 2006 | 07:47 PM
babymac's Avatar
BOOST 4 LIFE!
The battery is a brand new optima red top
Old Sep 13, 2006 | 07:48 PM
babymac's Avatar
BOOST 4 LIFE!
Originally Posted by jasonv
plugs and wires
The plugs are brand new ngk's and what wires?? If you mean coils they all seem to be fine.
Old Sep 13, 2006 | 07:59 PM
NmexMAX's Avatar
dot dot dot ...
Cps ...
Old Sep 13, 2006 | 08:26 PM
babymac's Avatar
BOOST 4 LIFE!
Originally Posted by NmexMAX
Cps ...
Whats that??
Old Sep 13, 2006 | 08:30 PM
NmexMAX's Avatar
dot dot dot ...
Crank Position Sensor.
Old Sep 13, 2006 | 08:32 PM
babymac's Avatar
BOOST 4 LIFE!
Originally Posted by babymac
Whats that??
nevermind i figured it out. Do you eally think that this is my problem??
Old Sep 13, 2006 | 08:33 PM
babymac's Avatar
BOOST 4 LIFE!
Where is it located?
Old Sep 13, 2006 | 08:37 PM
NmexMAX's Avatar
dot dot dot ...
Right behind the crank....
Old Sep 13, 2006 | 08:40 PM
babymac's Avatar
BOOST 4 LIFE!
Can you please be a little more specific?
Thankyou.
Old Sep 13, 2006 | 08:42 PM
NmexMAX's Avatar
dot dot dot ...
Find your crank, it's right behind it, on the lower tangent.
Old Sep 14, 2006 | 08:32 PM
jasonv's Avatar
sorry i forgot maximas are coil on plug. do they all have good spark?
Old Sep 15, 2006 | 04:26 AM
Sniepre's Avatar
Hey everyone.. Sorry to hijack this thread, but I tried to post one and since I have not yet 15 posts I cannot, and apparantly I can't earn those posts in the test forum...
My max is having problems starting, too.. but its like the starter just dies completely.
I can whap it with a screwdriver a few times and it will start but it's been getting weaker over the last 6 months and more frequent. Do I just need to have the starter replaced for the 2nd time? the first time this happened I had it replaced but it didn't solve the issue.
Also, when inspecting it, I've found two cables that are disconnected, one male one female, but, they do not fit together. They are right near the starter but seem to be for different purposes, both disconnected. One is red and one is black. Anyone know what these might be for or to where they go?
Here is a photo (click to enlarge)
Edit: They do reach each other, just one has 3 holes in the socket (red) and the other has one wide blade in the plug (black) ((even though the black looks like a socket and the red looks like a plug.. *shrugs*))
Old Sep 15, 2006 | 06:36 AM
RiggZola's Avatar
babymac, I had the same problem a few weeks ago. Two problems:
1. Dying battery. New battery - helped a little especially since it's getting cooler in the morning.
2. Dying coil. This reared it's ugly head this week with alot of stumbling and service engine light coming on - replaced it and *poof* easy starting.
BTW ... my service engine light comes on every year just before emissions checking. What a pain!
Old Sep 15, 2006 | 11:04 AM
babymac's Avatar
BOOST 4 LIFE!
I have no check engine lights.
Old Sep 18, 2006 | 12:23 PM
babymac's Avatar
BOOST 4 LIFE!
You wouldn't happen to know the part number?
Thnaks for the help.
Old Sep 18, 2006 | 12:28 PM
gassian's Avatar
babymac...try grounding your trannny.
Old Sep 18, 2006 | 12:29 PM
MaximaSE96's Avatar
Maxima Owner
could also be an injector bleeding off fuel pressure.....i had that happen on my 3rd gen.....but check the CPS first
Old Sep 18, 2006 | 04:24 PM
babymac's Avatar
BOOST 4 LIFE!
Tried it NO sucess. I think I'm going to try the crank position sensor, but the only thing is there is no cel. Wouldn't there be a cel if it was bad??
This problem is making me go crazy
Old Sep 18, 2006 | 05:58 PM
overseaz's Avatar
May want to try replacing the ignition switch its cheap and if it dont fix ur problem just return it. it cost me $38 bux at nissan and it fixed 2 of my problems. That was one of them odd but true.
Old Sep 18, 2006 | 06:01 PM
babymac's Avatar
BOOST 4 LIFE!
I'll put it on the list
Old Sep 18, 2006 | 06:02 PM
XtinctWS6's Avatar
good luck with this, I have the same problem. I've come to the conclusion that its a fuel problem. Its just a guess, but hopefully when I get it checked out next week it will be fixed. Ill let you know what the tech's say if you're still having problems.
Old Sep 18, 2006 | 06:06 PM
babymac's Avatar
BOOST 4 LIFE!
Fuel pump? But if it was that wouldn't my car run like $hit?? I mean wouldn't affect more then starting?? I don't know??????
Old Sep 18, 2006 | 08:49 PM
HYTE's Avatar
was just tryin to get some info on this problem myself and came across something that i havent read on any of the maxima sites. try changing the coolant sensor. http://auto.consumerguide.com/Auto/U...ewreliability/
check out that link from consumer guide magazine. thas something that has never been mentioned.
Old Sep 18, 2006 | 09:17 PM
NmexMAX's Avatar
dot dot dot ...
Not in this particular thread but a shyte load on this forum...
Old Sep 18, 2006 | 10:16 PM
sam29281's Avatar
ignition switch
it's very cheap.
http://www.rockauto.com/ref/Airtex/D...tml?1S6365.jpg 23 bux
the plastic inside the switch wears out... this cause starting problem when the key is turned but it doesn't turn the switch all the way.
If your starter is good, ..it's very likely this problem. Starter relay will rarely go bad..almost never(starter relay are cheap though).
check the fuse under on the driver side under panel. There is a fuel pump fuse.
Old Sep 19, 2006 | 03:44 AM
babymac's Avatar
BOOST 4 LIFE!
If the crank position sensor doesn't work should I try the coolant temp sensor or the ignition switch??
btw I really appreciate everybodies help.
Old Sep 19, 2006 | 03:47 AM
babymac's Avatar
BOOST 4 LIFE!
I think I might try the coolant sensor first since is only about 18 bucks. Can anybody tell me where iy is located?
Old Sep 19, 2006 | 03:50 AM
babymac's Avatar
BOOST 4 LIFE!
I looked yesterday and found exactly where it is.
Thanks.
Old Sep 19, 2006 | 08:14 AM
gassian's Avatar
the coolant temp sensor is located right after your rubber hose coming off the radiator from the front of the engine. You will see it screwed to a metal piece from that rubber hose..
I can't get a pic now but did my best on describing..
good luck...
BTW..i replaced my coolant sensor --> nothin
replaced ignition switch --> you feel difference but was still there
grounded the tranny and the starter itself and there was a difference
Old Sep 19, 2006 | 08:44 AM
sam29281's Avatar
h'bout a quick video of it starting? a lil camera phone would usually have those function.
Old Sep 19, 2006 | 05:29 PM
babymac's Avatar
BOOST 4 LIFE!
Well just replaced the coolant temp sensor and NO difference. Its funny it only does it when it sits fro a few hours?? I guess I'll try the crank position sensor next
Old Sep 24, 2006 | 08:52 AM
dovetailguy's Avatar
Starter
I had the same problem, the only thing I had to do was tighten the nut to the power supply.
Old Sep 24, 2006 | 05:23 PM
97maximaman's Avatar
CPS dude, had the same problem last year round this time and had exactly the same symptoms, i had the cps changed and no problems since. A word of the wise, dont hit the gas pedal in an attempt to start the car, i did it and ended up flooding two o2 sensors. Big money.
Old Sep 24, 2006 | 06:09 PM
babymac's Avatar
BOOST 4 LIFE!
Next on the list after of course the starter that just went bad on me
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
