Weird rustling/ruffling noise when I make turns...
Old Sep 14, 2006 | 07:36 AM
ComradeJew's Avatar
Hi all,
When I make turns at low-mid speed - between maybe 20 mph to 40 mph, I hear a ruffling/rustling/rubbing noise - its really faint but I can still hear it. Now, my front tires are Yokohoma ES100 (225/55/16) on Enkei RS5 - they are crap and they are very very low tread (I will take a pic soon).
Another thing is that the sound is not consistent with speed, well not quite - the recurrance would speed up, but not linearly with the speed...
So - could that be a warning side from the tire that I REALLY should get new tires?
Old Sep 14, 2006 | 08:03 AM
ComradeJew's Avatar
Anyone? This is scurrin me
Old Sep 14, 2006 | 09:16 AM
ComradeJew's Avatar
And now with pix:
Old Sep 14, 2006 | 09:17 AM
ComradeJew's Avatar
Old Sep 14, 2006 | 09:24 AM
MaxFanatik's Avatar
if it is like metal sound, check ur exahust if any hangers or clamps or broken, my rear one was broken and it made it sound like front axel was bad when id di tunrs under 20-50 mph range
Old Sep 14, 2006 | 09:25 AM
Mxrider52's Avatar
I support for what?
When did you notice this sound? Is the sound coming from 1 side or both? Roll up the windows and turn off the radio and listen real good to see if you can figure which side if you dont know.
Old Sep 14, 2006 | 09:26 AM
BlackCat's Avatar
RIP '98 Maxima SE
Is the inside tire wall rubbing against the wheel well?
Old Sep 14, 2006 | 09:47 AM
ComradeJew's Avatar
This was my first suspicion - when the wheel is all the way to one side, it's barely touching it - but I don't know about when it's only slightly turned.
It's not a metallic sound - more like "woosh woosh woosh" - clench your teeth, spread ur lips and push air through - thats the sound.
Old Sep 14, 2006 | 09:53 AM
Mxrider52's Avatar
I support for what?
I cant really say but it could be the wheel bearing. But I do not know if the noise is coming from 1 side or both. Jack up the car. Wiggle the wheel around up and down. If there play in it you need a wheel bearing.
Old Sep 14, 2006 | 10:04 AM
ComradeJew's Avatar
No play (did it last week).
Old Sep 14, 2006 | 02:19 PM
ComradeJew's Avatar
Bump; any mode ideas to share with me?
Old Sep 15, 2006 | 06:06 AM
ComradeJew's Avatar
last ditch effort
edit: as I was driving to work today, I noticed that after the car warmed up (or more like drove about 3-4 miles), the sound dissapeared... bad tires is my main suspicion now...
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
