tranny drain
Old Sep 17, 2006 | 10:43 AM
NyCzBuBBa's Avatar
tranny drain
what ATF should I use for an automatic transmission? How many quarts>?
Old Sep 17, 2006 | 01:21 PM
NmexMAX's Avatar
dot dot dot ...
Holy mother of big azs sigs..
Use 9.4 qts of Nissan "D" matic
Old Sep 17, 2006 | 03:19 PM
sky jumper
no, for a drain that would be ~ 4.5 quarts. and you can use any cheap dexIII you want.
Old Sep 17, 2006 | 05:07 PM
dr-rjp's Avatar
Mobil 1 full synthetic.
It is well worth the extra money!!
Old Sep 17, 2006 | 05:20 PM
jtmaxima's Avatar
transmission fluid
I called the dealer the other day to find out what fluid to use because the owners manual only states Nissan D matic fluid. The dealer said that I could only use the Nissan fluid and nothing else. The problem is the dealer is 180 miles away. I thought they might recommend something else once I told them how far away I was but they stuck with saying I should only use the Nissan fluid. I checked the Mobil1 website and their ATF didn't say anything about being compatible with Nissan's. It sounds like Mobil1, Amsoil, or Dextron III will work. Is this correct?
Old Sep 18, 2006 | 06:14 AM
NmexMAX's Avatar
dot dot dot ...
FSM states any equivalent fluid is fine.
Mobil 1 and Amsoil exceed Nissans std.
Dex III exceeds Dex II which Nissan states as equivalent(DexII = D matic).
Forge277
Jun 13, 2016 09:26 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
markevans999
Sep 10, 2015 04:29 PM
pktaske
Sep 4, 2015 08:40 AM
