uhhohhh no gas guage
Ok so i took my guages out to add some leds in the needles and used some sand paper to grind the black off the sides. Well when doing this the gas needle moved ofcoarse and i did not remember to put it back in place when i put dash back together so when i noticed on my way back from work. I opened it and put it back where i remembered it was last now i did that and it stayed in place so when i came back outside the needle dropped at about the 6-7 o'clock position and will not realign itself. Now my question here is did i break it and need to buy a new guage or what can i do to fix this problem
not much first hand experience with the needle adjustments, but I would try adjusting the needles again to where they should have been ,and see what happens.
You have driven the car some since this happened right? so the guage would have been at a lower place that where you reset it to.
You might end up buying another guage cluster and pulling out the gas guage and installing it onto yours.
well i tried fixing it and it went back down to hanging position i will try tomaro with engine on maby it will catch or something if not i guess i will have to buy new guages heh because i dont want to run out of gas
Originally Posted by 95SEfreak
looks like total crap heh not very bright at all so i guess im in the market for new guages but if someone sells me guages will the ecu configure the gas to whats in the tank?
find a 98 or 99 cluster.. with near or same miles... then just re wire.. jsut get the FSM from g20.net and you can do it .. 95% of the wires are the same color .... between them.. then the rest are easy to figure and the ones left over are for ground so.. its a project...
make shure you get the plug that plugs into the back of the 98-99 cluster all 3 of them
i've moved my gas gauge before, but it always resets itself when I plug it back in. There is a thread here that explains calibration mode, I'll see if I can find it....
EDIT: just realized you have a '95, no calibrate mode for you.
ef9
Oct 4, 2015 08:43 AM
