Installing rear springs.... Help
Old Sep 17, 2006 | 10:44 PM
WhiteMaxima9600's Avatar
Guys im sure this is in the stickies somewhere, but i did not see a write up on how to install strut/springs.. I know how to replace the front assembly but not really familiar with the rear setup.. Could someone send me a thread or a site showing this? I appreciate it..
Old Sep 18, 2006 | 12:30 AM
__Kevin__'s Avatar
Crack the center nut, but again do not take the nut completely off, just loosen. you break the center nut by using the smallest open end wrench you have (I think i used a 1/4") or an adjustable wrench to hold center bolt on it's flat edges. use another box end wrench (ratcheting is great, but you can get by w/reg box end or crescent wrench) to turn the nut. again, break it loose, but do not take nut completely off.
top is held by two nuts, take those off and take off lower bolt. rear suspension should drop out. put on compressors, compress spring. remove top center nut. remove hardware. put new springs on struts. put top hardware on new assembly. no bearings to grease here. compress spring and put center bolt on. you will not be able to completly torque center bolt till it's on the car so just get it on a few turns.
put assembly up into car and get the two upper nuts on.
get lower bolt on. you may need to rotate assembly to get it to line up. note try to get allignment of upper bolts and lower hole to match that of the car so you don't have to twist the spring a lot and risk unscrewing the center nut. once you have bolt and nuts on torque them down to stock specs...think it's like 110 for lower and like 65 for upper again. tighten center bolt using 1/4" and crescent wrench. lower car down. do not be surprised if you car isn't that low as things need to settle a bit. take to an allignment shop if you can. good luck
Old Sep 18, 2006 | 03:55 AM
njmaxseltd's Avatar
You do not need a spring compressor for the rear springs. They are under very minimal preload. Pops up about 1 inch after the nut is taken off.
If your putting on lower/sport springs, you don't need to compressor to get them on either. You can get stock springs back on with the help of a friend as well.
Old Sep 18, 2006 | 08:51 AM
Swazey's Avatar
i spring compressor makes everything a lot easier. i have one of those manual ones. it works great!
Old Sep 18, 2006 | 09:32 AM
__Kevin__'s Avatar
Yeah, Those were just some Instructions that I was sent when I bought My Springs/Struts, I just figured I'd pass that information along.
Old Sep 18, 2006 | 09:40 AM
Seems like the rear isnt too difficult then, im gonna get a loaner spring compressor from the parts store since it's free. I appreciate the advice.
Old Sep 18, 2006 | 10:23 AM
4x4Max's Avatar
If you know how to do the front, then you wont have any trouble with the back, dont really need any directions, its simple once you see how everything is assembled.
Old Sep 18, 2006 | 10:28 AM
Cdg2125's Avatar
Is the an actual write-up anywhere? I dont remember seeing one either. Not that I need it now, but still wondering.
Old Sep 18, 2006 | 11:35 AM
MDeezy's Avatar
there actually is a write up in the how to's stickie
Old Sep 18, 2006 | 09:55 PM
__Kevin__'s Avatar
The whole process is pretty easy. It took a friend and I about 2 hours to do the whole thing. Just remember to double check and make sure you're not forgetting anything.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
ef9
Aug 27, 2015 07:21 AM
maxipower
Aug 21, 2015 11:10 AM
Maxboy23
Aug 20, 2015 09:33 AM
