need help! in the process of removing carpet
Old Jun 26, 2001 | 09:55 PM
Ch12i5
i took out my front and rear seats, center console, kickplates, and kick panels.
(1)what else do i need to remove to yank the carpet out? the carpet seems like it can easily come off, but it goes into teh center dash. SWEETSOUND2001 has recommended to cut it out, and if that's the only way, (2)how would i do that?
if there's an alternative way, i'd like to know about it.
also, (3) how do you remove the top pillars on the left and right side of the dash, and the center pillars where the seat belts are?
thanks!
Old Jun 26, 2001 | 10:10 PM
Whitemax's Avatar
Disco Biscuit
I ran across the same problem. I was too lazy to rip out the dash, or even cut it, so I just wroked around it. It took a little to manhandle, but I was tired, hot, and hungry. I'd say cut it out.
As far as the pillers go, I think they just snap in like the rear pillar covers.
Old Jun 26, 2001 | 10:38 PM
Ch12i5
whitemax...
do i need to put RAMMmat on the floor of the car? or would heat shield insulation work? and in how many layers?
thanks!
Old Jun 26, 2001 | 11:37 PM
SWEETSOUND2001's Avatar
other things need to be done to remove the carpet. Unscrew the seatbelt bolts for passenger and driver. Unclip the lower part of the center pillars on both sides. And cut the carpet in the place where it goes behind the dash ( near the ecu)
Let us know what happens. Good luck.
Old Jun 26, 2001 | 11:42 PM
Ch12i5
so far this is what i've done...
i've taken out the carpeting all the way to the front dash...when i cut it, how will i be able to put it back? just with some glue?
thanks for your help whitemax and sweetsound, us three seem like the only ones crazy enough to do this kind of stuff
Old Jun 27, 2001 | 06:54 AM
Whitemax's Avatar
Disco Biscuit
Crazy's a good word for it I did not do the floor, only becuase I only had two rolls. If you're going to put down the heat sheild, I don't think you need the RAAMmat. I would just put down a layer of the heat sheild and see what happens. I noticed there is already some decent padding under the carpet, and with just 1 layer it was pretty thick.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
