Are 96 & 97 exhaust systems the same?
Old Sep 19, 2006 | 07:17 PM
Nathan's Avatar
I need a replacement y-pipe & b-pipe for my 97SE and have a couple local guys selling used Budget pieces. 1 guy has a '96 & the other has a '99.
Would a 96 have the same y-pipe as a 97, or are the locations for the 02 sensors different? How about the '99 y-pipes? I appreciate the help.
Old Sep 19, 2006 | 07:32 PM
'96 B-rad's Avatar
They should be the same since its the same generation. 95-99 should be the same. Just look at any website that sells them its for 95-99.
Old Sep 19, 2006 | 07:53 PM
96sleepergle's Avatar
the 97 max has an o2 sensor hole in the b-pipe 95-96 doesnt so get 97 to avoid drilling a hole in the 96 pipe if its used most likely to have rust on it just get a new one that fits your car
Old Sep 19, 2006 | 07:57 PM
'96 B-rad's Avatar
Oh I was only looking at the y-pipe didnt see b-pipe
Old Sep 19, 2006 | 09:31 PM
sunten1
The Y-Pipe is different for 95-98 and 99. 99 You have to find out if its cali-spec and all that BS. Just buy the 96 for your 97 and you should be find.
The difference in B-pipe is the 95/96 has a o2 sensor on the cat, while the 97-99 has it on the B-pipe.
Old Sep 19, 2006 | 10:48 PM
MorpheusZero's Avatar
All the fed-spec 95-99 y pipes should be the same. B pipes I'm not so sure on.
Old Sep 20, 2006 | 04:36 AM
MaximaSE96's Avatar
Maxima Owner
no all the cat-backs are not the same as fore mentioned the 02 bungs are different..and fed and cali spec y-pipes are diff...and i think 97-99 are a wee bit longer like an 1" or so.....not taht u cant get them all to work it just requires modification
Old Sep 20, 2006 | 07:51 AM
Nealoc187's Avatar
SLOW
97-99 B pipes are 6" SHORTER than 95-96 B pipes are. This is because the 97-99 cars have a pipe called an S-pipe in between the cat and the B-pipe that the 95-96 doesn't have.
Old Sep 20, 2006 | 07:54 AM
MaximaSE96's Avatar
Maxima Owner
that what it is...i knew one was longer than the other
Old Sep 20, 2006 | 09:13 AM
Apparition's Avatar
Ichiban King
..why dont you search? is your friend.
Old Sep 20, 2006 | 04:59 PM
Nathan's Avatar
Thanks for your great insight. Unfortunitly I have a job & I'm fixing this car which is my parents, so I didn't have time to search google.
I appreciate everyone elses help though. I have some big decisions to make.
Old Sep 20, 2006 | 05:42 PM
Apparition's Avatar
Ichiban King
well, I sure as hell hope you "have the time" to do other things on the car right. I work too and it doesn't mean I have to half-*** everything. Searching will provide more info, quicker..
so congradulations friend, you've found yourself a paradox.
Old Sep 20, 2006 | 07:50 PM
Nathan's Avatar
Your a smart @ss eh? Since you're a newbie I won't bother arguing with you. If you don't have anything to contribute to the thread. Get lost.
Old Sep 20, 2006 | 07:54 PM
Apparition's Avatar
Ichiban King
haha, a newbie .. don't be mad because I spearheaded your argument with logical reasoning. Btw, I did contribute but you were too arrogant to listen.
Old Sep 20, 2006 | 07:57 PM
Nathan's Avatar
There is no point searching on google because most websites will tell you that the exhaust system for all 4th gens are the same, which they are obviously not. This is why I would rather get the advice of maxima.org members.
Old Sep 20, 2006 | 08:00 PM
Nissan 6's Avatar
Apparitions insights have provided us with much knowledge he is far from a newbie
Old Sep 20, 2006 | 08:11 PM
Apparition's Avatar
Ichiban King
I meant use google to scour the .org forums, since you haven't donated. If you would have done that, you would've saved that precious time you seem to have wanted to retain..
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
