Crankshaft Pulley Broke?
Old 09-23-2006, 08:38 AM
sean05's Avatar
Hum.. About a week about my ac/alternator belt shreded. so i got a new gatorbelt and tossed it on. About two days ago it started squeeking again so i assumed it has stretched and it was time to tighten it again. Well today I was almost home then i hear it go, THUMP THUMP THUMP. i pull over in a parking lot and see that this big pulley had fallen off:
got home and looked inside and saw this:
Im completely lost with this one. I beleive its the crankshaft pulley. But on the crankshaft pulley this is 2 parts, the inside and the outer ring. The inside is fine but if im right, the outer ring is what fell off.. Heres a close up of it:
So if i am right, will i need to get a whole new pulley? or how was this sucker held on before? It looks like a rubberish glue, or is that something that happened becuase it broke? Please help!
Sean
sean05 is offline
Old 09-23-2006, 09:08 AM
matts95max's Avatar
might as well get u/r pulley?? but stock replacement or not you will probably be better off getting a new crank pulley rather than trying to get a away to put that back on there. wow I have never seen/heard of that b4! you must drive really fast lol j/k
matts95max is offline
Old 09-23-2006, 09:15 AM
sean05's Avatar
me either. hopefully someone on here has seen it before. scared the bageezus out of me. if i plan to go s/c is there any benefit to the u/r pulley?
sean05 is offline
Old 09-23-2006, 09:27 AM
nitromax's Avatar
it's rare, but does happen. i see it more with domestic vehicles. there's a rubber insulator between the inner & outer parts that goes bad. you need a new balancer or atleast another one. dealer or junk yard.
nitromax is offline
Old 09-23-2006, 10:09 AM
WhiteMaxima9600's Avatar
I almost had that same problem a couple of years ago, except mine just got off track a little and was turning my belt sideways... The rubber i belive is a harmonic balancer, nevertheless you have to replace the entire crankshaft pulley.. Ran me about $250 from the dealer, no autoparts store could get one for me.... You will also need a long pry bar to loosen that pulley bolt, its on really tight!! I was raising the motor up just prying on that thing, after that it's not to difficult just be sure to tighten the bolt to specs before you put the belt back on......
WhiteMaxima9600 is offline
Old 09-23-2006, 10:13 AM
Father of the 00 VI
krismax's Avatar
i have one with 35k on it if you need it
krismax is offline
Old 09-23-2006, 11:40 AM
VK56 Inside
Dubbya's Avatar
WOW. Thats pretty crazy. Go with a Unorthodox UDP.
Dubbya is offline
Old 09-23-2006, 11:43 AM
Old enuf to pick his own gears
d00df00d's Avatar
The crankshaft pulley is NOT a harmonic balancer, nor is ANY PART of it.
The rubber is just there to absorb some vibration. Over time, it can dry out, crack, and break. No big deal... You will just need a new pulley.
d00df00d is offline
Old 09-23-2006, 11:56 AM
I'm nutty for Nissans
JSutter's Avatar
That sounds like a harmonic balancer to me.
http://www.cartalk.com/content/colum.../March/09.html
Dispite what everyone has said in the past about the Maxima pulley not being or having a harmonic balancer, there IS rubber in the pulley. That means it does absorb some amount of vibration. Call it what you will, but the rubber isnt there for nothing.
JSutter is offline
d00df00d's Avatar
Or their Ultra Sc, which is still lighter but is the same diameter as stock and won't require a different belt.
d00df00d is offline
Old 09-23-2006, 12:20 PM
Wild for Width
Fr33way™'s Avatar
I taped a Harmonica to my Motostorm
Fr33way™ is offline
Old 09-23-2006, 12:53 PM
NerdManXdx's Avatar
Do not get an underdrive pulley if you're planning to go s/c. I don't know much about supercharging but I assume the Ultra Sc version d00df00d mentioned should be fine though. I also have an oem pulley laying around if you want to buy it. Don't forget to replace the oil seal when you replace the pulley.
NerdManXdx is offline
Old 09-23-2006, 01:18 PM
MDeezy's Avatar
Wow, Odd that this happened but replace with an UDP if you want to try and free up a little power and rev a little faster.
For than crank pulley bolt. Get a long brake bar, have someone hold it on the bolt and let someone crank the car in bursts. Should break the bolt free pretty easily.
MDeezy is offline
Old 09-23-2006, 03:34 PM
sean05's Avatar
I got a price at the stealership. They quoted me 250. I do plan on going supecharged here soon. I know the only two options, a stock pulley or the UDP SC which is still the stock diameter. Im probably going to go with the SC becuase its lighter plus is the same size (hopefully). Some guys in the FI section had a few defective ones that were still smaller then stock.
sean05 is offline
Old 09-23-2006, 04:01 PM
MDeezy's Avatar
You could get a crank pulley for $30 from a junk yard, or a member online here would sell it much cheaper than $250. But getting the UDP SC from now would be a good move if you know you will go boost later.
MDeezy is offline
Old 09-23-2006, 04:07 PM
nismology's Avatar
The ONLY reason to get an UDP is it's probably cheaper than the OEM piece.
nismology is offline
Old 09-23-2006, 04:20 PM
YoU CaNt SeE mE
Maxima-4DSC's Avatar
if it was me id be thrilled i have a solid reason to upgrade....time for lightened pulley ! not an UP just a lightened one.
Maxima-4DSC is offline
Old 09-23-2006, 06:18 PM
Yep $250 is what a oe crank pulley will cost ya, all the auto parts guys told me that it was a harmonic balancer/pulley in one so.......whatever? Guess it don't matter b/c u have to replace the whole thing anyway
Old 09-24-2006, 05:52 AM
sean05's Avatar
even with going boosted? If i was getting the Ultra SC from Unorthodox.
sean05 is offline
Old 09-24-2006, 06:50 AM
matty's Avatar
Stay STOCK when you go SC. Contact someone, get it used...or just get a new on from the dealership. Ive seen that happen before
-matt
matty is offline
Old 09-24-2006, 06:51 AM
nismology's Avatar
You'd be hard-pressed to see any gains from an UDP, boosted or not. I'd get a lightened flywheel before that. Then again, you might save some $$ by getting one.
Old 09-24-2006, 06:59 AM
sean05's Avatar
thanks guys. im going to see if i can find one used from an orger. As right of right the car isnt driveable correct?
you got a PM
sean05 is offline
Old 09-24-2006, 07:21 AM
MDeezy's Avatar
I would not drive the car.
MDeezy is offline
Old 09-24-2006, 07:47 AM
d00df00d's Avatar
Despite how often people get them confused, a crank pulley, a vibration damper, and a harmonic balancer are three different things. Kind of like they're, their, and there.
The crank pulley on a VQ acts as a vibration damper, but it is not a harmonic balancer. The VQ is internally balanced.
As for the UDP vs. Ultra Sc debate... An Ultra Sc pulley will help you rev faster and may free up some horsepower because it is lighter than the stock pulley. An underdrive pulley (UDP) will do the same things, but it will do them a little better because it is smaller and even lighter, and, due to its smaller size, also takes less power away from your engine to drive your alternator and air conditioning compressor. Most people don't really notice the loss in electrical power or AC efficiency unless they have big audio systems.
It's important to note that both pulleys are solid and do not have vibration dampers. Also, the UDP will require you to use a smaller accessory belt. Take those as you will.
d00df00d is offline
Old 09-24-2006, 08:35 AM
sean05's Avatar
Well I'm stuck. I dont know if I should just grab a used stock pulley, or if it would be better for me to get the Unorthodox pulley thats lighten but still the same diameter as stock for when i go boosted. Matty suggest just going stock . How much would a lightened pulley help out when i switch over to supercharged?
Im not. I get to ride around in this bad boy:
sean05 is offline
Old 09-24-2006, 08:37 AM
Thanks for clearing that up for us.....
Old 09-24-2006, 09:09 AM
nismology's Avatar
There's been no precedent set with 1/4 mile times that substantiates the claims that the UDP does anything more than look pretty. The theory is sound, but practical > theoretical. I can explain why, but I don't want this to too far OT though, so i digress.
Old 09-24-2006, 02:06 PM
d00df00d's Avatar
Well, if you're supercharging, you probably won't notice a difference with the Ultra Sc pulley. The only reason to get it would be if you wanted a guarantee that it won't break like this again.
Otherwise, just save yourself a ton of money and get a used stocker.
d00df00d is offline
Old 09-24-2006, 04:19 PM
njmaxseltd's Avatar
A new OEM crankshaft pully is $180 from Pinnacle Nissan.
http://www.trademotion.com/partlocat...99&catalogid=1
I wouldn't put a used pully on the car.
Rubber deteriorates over time and a used pully from a 4th gen is getting, ummm shall I say... old regardless of mileage.
njmaxseltd is offline
Old 09-24-2006, 05:02 PM
d00df00d's Avatar
^ Good advice.
d00df00d is offline
Old 09-24-2006, 05:19 PM
4x4Max's Avatar
Same thing happened to me maybe 2 months ago, the EXACT same thing. I ended up buying a used UR UDP from a member here for a great price. Power gains and quicker reving? Maybe, but small stuff adds up, its like weight reduction. I went with an aftermarket pulley because of the 1 peice design, i know it won't break into peices like the stock one did, and it was cheaper also.
4x4Max is offline
06-06-2017 02:01 PM
02PearlSE
02-01-2016 12:37 AM
rbarnes
12-31-2015 06:29 PM
hayne
10-05-2015 11:53 AM
Quick Reply: Crankshaft Pulley Broke?
