Intake Manifold
Old Sep 24, 2006 | 09:31 AM
maximaman10's Avatar
Intake Manifold
How hard is it to take off the upper intake manifold to cleanm out the carbon for the EGR system? I keep getting a code for the EGR valve malfunction even though I put on a new EGR valve.
Old Sep 24, 2006 | 11:19 AM
Please someone help me. I'm tired of seeing my check engine light come on again after clearing the codes. I'm not willing to give the Stealership $270 dollars to do it for me.
Old Sep 24, 2006 | 11:29 AM
Cdg2125's Avatar
Well you can do the job. You'll need a torque wrench to torque the correct weight back to the bolts but it shouldnt be too difficult. Do you have a Haynes manual?
Old Sep 24, 2006 | 11:34 AM
No, I have a Chiltons and a Nissan service manual on disc.
Old Sep 24, 2006 | 11:38 AM
Tatanko's Avatar
Bacon Lover
Those will suffice. The FSM will probably do more for you than a Chiltons or Haynes ever will.
Cdg2125's Avatar
Ok well go into that and see about removing the intake manifold. As long as you have the tools and the knowledge of what you're doing you should be able to do it.
Where'd you get your FSM Tatanko?
Old Sep 24, 2006 | 11:41 AM
Tatanko's Avatar
Bacon Lover
phatg20.net
However, any time I've tried to download it from there, it's missing the EC (engine control) section. I had to get that particular section from another member.
Old Sep 24, 2006 | 01:26 PM
Cdg2125's Avatar
Whats in the engine control part? Any chance you could send me that?
Old Sep 24, 2006 | 01:50 PM
Tatanko's Avatar
Bacon Lover
It's just labeled EC on the list of sections. It has to deal with the ECU, sensors, etc. Drop me an email at pmitchell1@gmail.com and I'll send it your way.
Old Sep 24, 2006 | 01:59 PM
Cdg2125's Avatar
hey thanks a lot. I'll send an e-mail once I get back to my dorm tonight.
Old Sep 26, 2006 | 03:59 PM
sportbikenut's Avatar
I've got the same exact problem. Any chance you can email me the section from your FSM on intake man. removal? Thanks!
Old Sep 26, 2006 | 04:10 PM
KRRZ350's Avatar
I've done 4 and it's really not that bad, the hardest part is getting at the back bolts for the egr and the manifold brackets, it's alot easier if you have a (10mm?? & 12mm??) gear wrenches. Use a 3m scuff pad and then brake cleaner and a rag to clean all of the surfaces. Other than that it's just simply disconnecting of clips, wires, hoses, and brackets, just be gentle on that wiring harness
Old Sep 26, 2006 | 04:58 PM
speed racer's Avatar
I think the hardest part is getting the coolant line off the intake manifold in the rear. Its best if you can get needle nose plyers or 45degree needle nose plyers. That should help with taking the clamps off the coolant line. Everything else is just simply unbolting or removing a hose hear and there.
Old Sep 26, 2006 | 06:30 PM
Did you replace manifold gasket or use RTV sealant or original? Thanks.
Old Sep 26, 2006 | 07:02 PM
Tatanko's Avatar
Bacon Lover
Use a new gasket. They are extremely cheap at Autozone, Advance Auto, etc.
Old Sep 26, 2006 | 07:14 PM
mowgli29's Avatar
Horizontally opposed.
I just had my upper and lower manifold off a while back to get all the carbon out....just used some brake cleaner and a rag to wipe out the lower, then filled the upper manifold full of acetone and let it eat all the carbon out for a couple hours....runs like a champ! and I would have to agree with the others, the rear bolts on the manifold are a pain as well as the coolant lines upon re-install....hope you've got some patience, good luck!
Old Sep 26, 2006 | 07:49 PM
matts95max's Avatar
big hands?? real hard, little hands? doable.
Old Sep 26, 2006 | 07:55 PM
vsamoylov
or order one from daveb.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
