Yes... another exhaust question... but this one's easy!
Old Sep 25, 2006 | 02:35 PM
Chefasaurus's Avatar
Fire in the hole!
I'm buying the Budget Y-pipe this week, and then will highly consider the rest of the exhaust components...
But on my 99, there's this little 6-8" extension piece that connects from the cat to the B-pipe... what is out there to replace it?
It looks like it's 2 1/2" at the inlet, but when it makes its bend, it looks like it drops down to nearly HALF of that. WTF?
Does the Budget y-pipe and test pipe replace all that?
--Evan
Old Sep 25, 2006 | 02:57 PM
sunten1
First thing make sure you know if your Cali spec or not.
As for the extension, don't worry about that. If you buy a Cat back later it will cover all that.
The budget Y and cat will replace exactly that, the y and the cat. That extension is on the bpipe
Old Sep 25, 2006 | 03:13 PM
pimpsmatt's Avatar
i was wondering the same thing when i came across this:
http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Courtesy%20B-Pipe%20Restrict.htm
(copy/paste)
but this pertains to the courtesy b-pipe. i havent heard of any of these issues with the budget b-pipe.i have this horrible restriction on my 98 i30t, but its not calispec. i went to my local middas shop and they said they could make a peice to replace it with 2 1/4 or 2 1/2 pipe with an o2 bung for about 30 bucks, but i plan on buying a bundget b-pipe so i havent done it yet. the only thing im worried about is where to put the o2 sensor. does the budget have a place for it?
Old Sep 25, 2006 | 03:25 PM
RA030726's Avatar
I'm nutty for Nissans
Almost all cat backs or B pipes replace that pipe. They have an O2 bung just behind the cat already in their B pipes.
BTW the inlet of the s pipe is almost 3", IIRC its a tic over 2.75". It then squeezes down to 2"ish.
Old Sep 25, 2006 | 04:17 PM
chrisZ's Avatar
Not to hijack this thread, but the question will apply. After the y-pipe and b-pipe install, does the ECM need to be reset?
Old Sep 25, 2006 | 05:51 PM
Fire in the hole!
federal spec
Old Sep 25, 2006 | 06:07 PM
MaximaSE96's Avatar
Maxima Owner
no..........any compensation that the ECU may need to make it will do on its own
Old Jul 2, 2008 | 05:52 PM
maximase86's Avatar
I love lamp.
Originally Posted by vash.t.s.
does
Wow, you used a word to bump an almost 2 year old thread. Now this might be a stretch, but lets try making an entire sentence. Soon you might even have paragraphs.
I do have to say one really nice thing...good job, to pull this thread up, you used search. That's a good thing.
Apr 16, 2020 05:15 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
