Clutch has no pressure when pressed....
Hi guys, I was wondering can help mefigure this out. This morning when I went to start the car, I noticed that there was just no pressue on the clutch when pressed except towards the end. The clutch pedal feels loose. The car starts up but I just can't put it into gear. Does anybody know why ? I noticed that the clutch fluid was a little low and I filled it up a bit. I have yet to bleed it, but thought I'd ask in case there was another reason. I have a '98 SE. Thanks !!
Originally Posted by MaximaSE96
well there is still the question of y it was low
Hey guys, I just finished checking it out. I put fluid in and bleed it and now it seems to be doing ok. Thanks for all the tip. However, you are right that there is a concern as to how it was low to being with. When I took a look, there was oil residue on the clutch hose so I'm not sure if that was an actual leak. I say that only because we checked it through and through and there was no leak that we could see.
that is a pain in the rear end dude, i ve been having a problem with my clutch hydraulics for 3 years now. its cost me 2 clutches, motor mounts and axle vibration. i changes my rubber part of the line because parts were easy to find and i assumed that it would probably be the most delicate part of the line since its rubber. i dont even want to emagine what i would have to do if i find out its my slave cylinder, f - that, it looks like challenge, 4-5 on the difficulty chart, 1 or 2 is for most enthusiasts, with the aid of some good tools, and parts, you need to consider whether or not its worth your time. i know i would need help....
Originally Posted by MienMaxima
Yea, I just ordered a SS one and hopefully have it changed by the end of this weekend. I'll keep posted.
Originally Posted by sergofast
Where did you get the SS line from? I have heard these talked of, but dont know who sells them.
-Matt
Originally Posted by MadMaxSE-L
search around in the groupdeal section, IIRC they are in there somewhere...
-Matt
-Matt
Mar 12, 2020 12:06 AM
carlosvq30
Sep 26, 2015 09:44 AM
