List of Possible Poblems - Contribute
Lately my Max has been real sluggish. I remember when my mom(laugh) gave it to me, about 2 months ago, it was still kicking even with 140k.
Recently its been really slow, it doesnt have that take off or acceleration it used to and its eally got me worried.
Some issues/mods that might Help YOU to Help ME figure this out are:
1st mod - Hacked air Box. About a month ago, was still running smooth.
2nd issue - Check engine light for code 1005, 1008 has been on even before i got the car. So maybe thats not it.
3rd - Might need oil change, im just passing the jiffylube suggested date. Oil still appears very clean though.
4th- Cleaned EVAP/ and hoses - they were very dirty, the EVAP valve has white stuff built up inside. I took apart the plastic thing attached to it, and the prongs(electrical connections) were all rusted, some prongs fell out and are no longer connected, 3/6 prongs connected. later.
5th - I reset my ECU a couple times after mods and then after cleaning, since then its been sluggish.
6th- My coolent/antifreeze is leaking(previously posted). Refill it every week. I dont know where its leaking from. But its dripping from the oil pan, so it must be above that.
Havent checked the KS, going to pick up a voltage meter, but they're like 30-80$ at radioshack.
So, any other idea's what it could be?
I doubt the EVAP thing is causing it to go slow.
if you have dogged it all. drive it easy for a week. real easy. then give it hell . if if feels better . replace ur knock sensor now. other than that i cant help. unless uve just gotten tired of it. i have a friend with a 300z tt and after about 4 months of drivin it he says its slow to him now but its still fast as hell to me 345 dino rwhp so.... you never know
first off, the hacked airbox is a b/s mod-go get a stocker or glue the old pieces back in if you still have them; I did that to mine and it seemed to be slower and rougher, put a stocker back on and is much snappier and smoother, you have done nothing to increase the air intake requirements of you VQ so stock is fine...
fiz EVAP crap
if you cleared the ECM memory by leaving the BATT cable off for a while, then it may take some time to "re-learn" and adapt to your driving habbits, i.e. if you drive slow it will adapt for "economy" and if you drive like a bat outta hell then it will adapt for performance
where is it leaking anti-freeze from???
DEFINATLEY CHECK THE KS
fiz EVAP crap
Updated Pics of EVAP valve.
I'm trying to solder the connections back together, but the damn things wont grab/hold the solder. Its really falling apart...dunno if i can do it.
How much does one of these valve cost?
IS it important?
IS it important?
first of all, fix the EVAP stuff you broke. Go back to a stock air box, when mine was hacked, my car felt sluggish overall, especially low end power. If you have over 100,000 miles, i'd recommend you change your KS. Lastly find out what the codes are and fix them. By the way the antifreeze is probably you water pump weep hole.
How can i get to this weep hole? Is it fixable or does it need replacement?
jmlee44
Oct 2, 2022 02:13 PM
MaxLvr21
Oct 17, 2015 12:11 PM
hntwhttail
Sep 12, 2015 03:43 PM
