Stillen Kit goes on this weekend !
Old Sep 27, 2006 | 08:53 PM
matty's Avatar
Hey guys, I should be installed the Stillen Kit this weekend that I had painted, Ive jsut been waiting to get my Motor in and done with the paint and everything.
Double Sided tape works right ?? With self tapping screws on the sides of each side skirts, underneath the rear valances and on the ends of the front lip ?? How much tape do I use ??
Thanks Guys.
-matt
Old Sep 27, 2006 | 08:57 PM
ManualMaxima's Avatar
5th Gen till she dies!
i line the whole sides with tape form end to end. and tappedthe 2 scres in on the fender lip.
the front i put tape on the side untill the fog light, and on the lower opening of the bumper where the kits rest. I used 2 screws on the fender lips.
the rears i could never get to stay corretly. the are always hanging alittle bit and the back of the are where they end i can never get them to line up correctly and stay in place. i am going to take my rears to a shop and have they pop rivieted on.
Old Sep 27, 2006 | 10:49 PM
VIP Maxima
you just need two screws and thats for the front lip and u use it on the fenders. use two full rows on each side skirt from front to back. for the front lip, get as much as possible on there and the same story applies to the rear valances. basically, the more 3m the better ! if you ever have to remove the pieces, its gonna be very hard and ull need 3m adhesive remover. but hey, better than walkin to the car only to find out that someone ripped your $1000 kit right off and took it home !
Old Sep 28, 2006 | 04:42 AM
ethnic6's Avatar
^^^ what they said, hope to see some pics of ur ride soon
Old Sep 28, 2006 | 09:50 AM
MrDicks95SE's Avatar
Offset Is Everything.
for the front lip do the nut and bolt on the inner fender and either bolt and nut for the front or rivet the front for a cleaner look. double stick tape wont work for the lip. i tried. for the sideskirts, line the entire top side with 3M and screws on each end. secure the rear with either sticky tape or bolts on the underside and each end.
Old Sep 28, 2006 | 09:56 AM
Ceasars Chariot's Avatar
Old Maxima Legend
post up some pics when its all done, sounds good !
Old Sep 28, 2006 | 12:37 PM
RA030726's Avatar
I'm nutty for Nissans
I dont recommend the tape for the front. Chances are there will be a day when you need a tow, or something to be done that needs some extra clearance, and you wont be able to remove the lip in a jiffy. I have 5 screws on the lip, 3 in the middle under the license plate and 1 on each end, no tape. I had tape on it at first, but winter+ground=broke. It was a huge pain to get the lip off. Im not saying dont do it, but just keep this in mind. Also make sure you get 3M exterior mounting tape. Anything else will just fall off.
Old Sep 30, 2006 | 07:19 AM
mikem29ss's Avatar
Do they make a Stillen kit for a 95 Maxima? I did a little searching but only came up with 97 and up. Thanks
Mike
Old Sep 30, 2006 | 07:22 AM
Nismotic's Avatar
Always sunny in philly
Mike
yes, but the front lip is slightly different
Old Sep 30, 2006 | 07:31 AM
mikem29ss's Avatar
The 97 kit would work? What is the difference with the lip? Anything some time to modify can't overcome? Thanks
Old Sep 30, 2006 | 07:46 AM
Nismotic's Avatar
The stillen kit is identical for 95-96 and 97-99 except for the front lip. Either get the 96 lip or do a 97 front conversion for your car.
Old Sep 30, 2006 | 07:51 AM
mikem29ss's Avatar
Sweet thanks man
Old Sep 30, 2006 | 09:39 AM
Dave H.'s Avatar
The rear pieces are different too. THe 95/96 ones are shorter than the 97-99 because of the rear bumper being a little longer on the 97-99.
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
