Fog Light Problem HELP ME PLZ
Old Oct 1, 2006 | 05:13 PM
Black Maxima
I added stock fog lights to my car. When I first installed them I noticed the passenger side fog light was much dimmer than the driver's side. It blew out after a week or so, so I replaced the bulbs. This time after a week or so, both bulbs blew out. They were completly burnt. I replaced both fog lights, adjusted the passenger to match the driver side, and two days later the passenger bulb blew. The driver's side works still. I rewired them so they go on by themselves. What is going on here????????
Thanks,
Aaron
Old Oct 1, 2006 | 05:57 PM
Black Maxima
Bumpppppppp
Old Oct 1, 2006 | 06:07 PM
yevrah4728's Avatar
maybe u should try wiring them to the clearance lights instead. also check for short circuits...good luck...
Old Oct 1, 2006 | 06:23 PM
Black Maxima
I don't know, it shouldn't be doing this. Where should I check for short circuits?
Old Oct 1, 2006 | 06:25 PM
Black Maxima
No fuses blow...
Old Oct 1, 2006 | 06:39 PM
glenmoormax's Avatar
10 psi
Ibdriverdoordoesntopen
Old Oct 1, 2006 | 06:52 PM
Black Maxima
HAHAHAHAHAHAHA
Actually my passenger door doesn't open now. WTF
Old Oct 1, 2006 | 07:00 PM
10 psi
Originally Posted by Black Maxima
HAHAHAHAHAHAHA
I guess you will have to crawl through your driver side window to find out WTH is going on! OMG OMG!!! lol
Old Oct 1, 2006 | 09:46 PM
t65k3's Avatar
Still Learning
That's what I did the other day. Again, you might have to crawl through the other side like I do now.......haha...... How many Amps of fuses the factory fog lights use? Maybe you could find out the individual current that's pulled on each light by meter..... I am just guessing....... and trying to help~
Old Oct 2, 2006 | 06:34 AM
black97's Avatar
hahaha....
Old Oct 2, 2006 | 08:36 AM
MaximaSE96's Avatar
Maxima Owner
check all wiring for cracks....and shorts....were the lights used or new
Old Oct 2, 2006 | 08:50 AM
Black Maxima
The first ones were used. The other two times they blew they were brand new H3's.
Old Oct 2, 2006 | 09:36 AM
black97's Avatar
BTW check your fog lights may be there's problem with seals can you see any water in it after rain
Old Oct 2, 2006 | 12:37 PM
sunten1
Aaron try un-independently wireing them. Run those for a while and see what happens.
Old Oct 2, 2006 | 01:01 PM
Black Maxima
I will check everything you guys are saying when I get home from school this weekend.
Thanks for the replies!!!
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
