Exhaust question, PITA!!!
Old Oct 1, 2006 | 05:38 PM
HarrisH's Avatar
I got a stillen catback, the b pipe hits the frame of the body and it swings left and right which makes annoying sounds.
This has been going on forever.
I'm assuming I need to change my hangers bushing(s), how many do I need, how easy to install, and where are the ones that I need to replace. The b pipe hits under the car where it curves around near the rear tires, so right below the rear beam axle.
Old Oct 1, 2006 | 06:03 PM
NYC32798's Avatar
I'm not 100% positive but I think there is 1 hanger for the b-pipe. I know there are 3 for the muffler. They are very easy to replace. Nismo makes aftermarket hangers which are stronger and harder than OEM but they are like $15 a piece.
Old Oct 1, 2006 | 07:07 PM
f550maranello2's Avatar
omg just go to the nearest exhaust shop and get them done there.. if they charge you anymore than 20 bucks go somewhere else...
Old Oct 1, 2006 | 07:42 PM
Ceasars Chariot's Avatar
Old Maxima Legend
i have been dealing with the same thing, different setup though, jack the car up and lay up under there. And have a look. My bpipe needed to be pulled to the left to keep from hitting, so doing anything to save money by not going to an exhaust shop, i had a look. then i spotted my left rear hanger bushing. I was able to use a cable tie and tightend it to some sort of rod above it.
not sure which way you need to go with yours but have a look under there, a simple cable tie might work for you too. its a ghetto mod for sure, but who in the heck is going to see it up under there ?
if you have a drill that can drill through thin metal you could also rig up a way to tighten it up that way as well.
food for thought, if it taste bad spit it out
edit: left hand side is the steering wheel side like LHD
Old Oct 1, 2006 | 09:02 PM
HarrisH's Avatar
You think if you replaced the bushings it might have fixed the issue? I'd rather just replace the bushings get done once and for all you know what I mean?
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
