99 cali spec MAF help?
Old Oct 7, 2006 | 08:14 AM
achebee4you's Avatar
well i just finished taking out my diy ram air and placed the oem air box back in. When i fired the car up i forgot to connect the MAF so my dumba$$ did it while the car was running. The car bogged while i pluged it in but than idle back to normal. So then i get in the car and damn the check engine light is on. So then i drove around for 20mins and the car ran better than before the infamous 99 rough idle was gone and the car acc better, granted i also changed my coils and plugs and now back to stock air box. Anyways i ran the codes and got 0102 = maf sensor issues. But the car runs fine in fact it runs better but tha light is still there.
1. How important is it that i change the MAF and do i need to since the car exhibits no problems asscoiated with a bad MAF? Plus is there a particualr one i need for the 99 cali spec gen 4 or are the all the same for all gen 4 95-99?
2. Should i try resetting the ecu again?
3. How long can i go with the light on, if in fact i do have a bad MAF what exaclty does this sensor do for the car so far even though currently the car runs fine. e.g. will the engine like over heat or will i get horrible gas milaega or some kind of catastrophic failure.
help guys
thanks
Tim
Old Oct 7, 2006 | 10:20 AM
ouch no has had a 99 cali spec with a bad maf
Old Oct 7, 2006 | 10:25 AM
RA030726's Avatar
I'm nutty for Nissans
the code is from you leaving it unplugged and then starting the car. reset the ECU and you should be fine.
Old Oct 7, 2006 | 10:27 AM
should i reset while the car is on or just in key at the on position?
Old Oct 7, 2006 | 10:28 AM
bc i just fired her up again and the engine light is still on
Old Oct 7, 2006 | 11:09 AM
RA030726's Avatar
so the code wont go out?
Old Oct 7, 2006 | 11:46 AM
the codes went out after i first reset the ecu but an hour later i restart it and the light is back on, i'm just confused bc the car is running fine it doesn't have any symptoms of a bad maf. I think i messed something up when in the maf the first time while the car was on. But currently no idle issues, acc, or rev nothing is it really a maf, ughh?? s
someone told me to unplug the maf while the car is off plug it back in and then reset the ecu
Old Oct 7, 2006 | 02:11 PM
i'm confusd anymore help
Old Oct 8, 2006 | 06:49 AM
how much should i expect to pay for a MAF
Old Oct 8, 2006 | 01:02 PM
adithius's Avatar
Hey you can either drive it for a a week or two and the code will go off or reset it. Dont replace the maf unless you need to. It will be a waste of money.
Old Oct 8, 2006 | 04:05 PM
oh thank you, i tried reseting it but the light won't go out, the car runs perfectly fine no sign of what is associated with a bad maf, there is a maf for sale on ebay used 90 warranty going for 10 plus 10 for shipping that ends tomm around noon. i just don't want to spend a lot of money on a new maf if i don't need it. Should i be experiencing anything if i do i have a bad maf?
Old Oct 9, 2006 | 02:38 PM
well the light is still on i'm still wondering if anything is wrong the car runs better than ever, this is so WTF??
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
