got nismo exhaust hangers and got a rattle..
Old Oct 11, 2006 | 12:22 PM
99se5speed's Avatar
SHIFT_up
I bought the nismo exhaust hangers (guy at Nissan had no idea wtf i was talking about and gave me "oem" but the one's i have are stronger and bigger then the oem) so i was barely able to fit them on because there so bulky and strong.
These hangers got rid of all the vibration I had in the shifter completely!!! and alot of other stuff that was related to my exhaust that I had no idea about. For some strange reason when i turn on the a/c the shifter itself literally vibrates & rattles now...wtf is up with that? Only when the a/c is on and I'm at idle. It doesn't rattle when I'm driving with the a/c but pretty much only at idle. It's so damn annoying, what could trigger this when everything is so much better with the hangers...i know this is stupid to even bring up but WOW it's so annoying Thanks.
away
Old Oct 11, 2006 | 12:27 PM
MadMaxima99's Avatar
When you are at idle with the AC on the RPM gets closer to stall then it would with the AC off. Its because you are putting a load on the motor. At lower RPM the engine will vibrate more. Thats why the car vibrates a hell of alot when you get close to stall with a MT.
Old Oct 11, 2006 | 12:34 PM
99se5speed's Avatar
SHIFT_up
I know but i'm not stalling the motor..and the rpm's aren't going down with the a/c on, there at 900 with the a/c. It's just that the damn shifter like the entire shaft or w/e rattles. Never happened before.
Old Oct 11, 2006 | 12:49 PM
well i got a 99 gxe, and mine does rattle also, but its not the AC thats causing it. I have my AC bypassed right now with a shorter belt, because i have to replace the bearing on the clutch. and it still rattles.
Old Oct 11, 2006 | 01:56 PM
99se5speed's Avatar
SHIFT_up
My exhaust used to rattle, i randomly decided to get the nismo hangers and it's a good thing i did because one of them was torn. After putting them on the rattle of the exhaust stopped and the shifter stopped vibrating in neutral and idle(this was caused by the exhaust), but the shifter itself started to rattle only with the a/c but doesn't even move when at idle.
Old Oct 11, 2006 | 02:08 PM
Fr33way™'s Avatar
Wild for Width
Punishment for spending so much money on an exhuast hanger?
Old Oct 11, 2006 | 02:32 PM
99se5speed's Avatar
SHIFT_up
acutally 2 of em ran me 10 bucks...can't complain
Old Oct 11, 2006 | 03:05 PM
sunten1
IIRC I think I paid 20 bucks for 2 in April. For OEM.
Old Oct 11, 2006 | 06:22 PM
Fr33way™'s Avatar
Wild for Width
I see $14.87/per from Courtesy.
Old Oct 11, 2006 | 06:35 PM
99se5speed's Avatar
SHIFT_up
^ well that's from Courtesy, my friend works at a dealership here in NY so i was able to scoop up there last 2 for 10 bucks.
Old Oct 11, 2006 | 06:43 PM
Cdg2125's Avatar
damn I had no idea that hangers ran so much. I'm installing my cattman b either this or next weekend and I'll probably need a few. Best place to go anyone?
Old Oct 11, 2006 | 07:51 PM
Fr33way™'s Avatar
Wild for Width
It's a piece of rubber. You can get them at Autozone (for example).
If your old ones are not torn I would zip-tie or hose clamp around those. Holds the system very secure.
Old Oct 11, 2006 | 07:55 PM
Cdg2125's Avatar
Will zip ties be ok with all that heat?
Old Oct 11, 2006 | 07:59 PM
Apparition's Avatar
Ichiban King
(sigh).. zip ties around the rubber hanger, in other words mad insulation added to the fact that the hangers are pretty cool in the first place. So, yeah they'll be fine..
Old Oct 11, 2006 | 08:01 PM
Fr33way™'s Avatar
Wild for Width
I have them as temporary around the b-pipe hanger. The thing is they don't hold it any TIGHTER, they just resist flex. The hose clamps keep the system nice and tight (although it SHOULD have some flex).
Old Oct 11, 2006 | 08:09 PM
Apparition's Avatar
Ichiban King
..damn trekkies, damn them all.
05RLS2
Apr 14, 2016 11:49 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
