Anyones else have problems with the bolts on the Cat?
Old Oct 11, 2006 | 04:27 PM
gblkrt09
My bolts on my Cat on both sides are rusted soooooo bad that the nuts are completely deformed, I tried heating them up, didn't work, what am i supposed to do next??
Old Oct 11, 2006 | 04:30 PM
mtrai760's Avatar
'Trynna' is not a word
Drill them out and replace them with new hardware. Sucks, but sometimes it has to be done.
Old Oct 11, 2006 | 04:34 PM
gblkrt09
Ya that blows, o well, weekend project
Old Oct 11, 2006 | 04:41 PM
White Shadow's Avatar
Still chugging along...
EVERY cat as old as ours will be like that. Cutting torch should make quick work of them. Be very careful though.
Old Oct 11, 2006 | 04:59 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i used my teeth
j/k i used a sawzall with a metal blade and cut in between the flanges.....done
Old Oct 11, 2006 | 05:23 PM
gblkrt09
and then when u did that u drilled holes and bolted on the cat and u were fine???
Old Oct 11, 2006 | 07:08 PM
NYC32798's Avatar
I just brought it to a shop and let them do it. They were rusted so bad that it looked like the bolts and flanges were one piece. They got them both out in 15 minutes.
Old Oct 11, 2006 | 07:10 PM
NmexMAX's Avatar
dot dot dot ...
Grind those little ****** off.
Old Oct 11, 2006 | 07:13 PM
Gismo-T's Avatar
B!tch We Got a Problem
Torch em' off
Old Oct 11, 2006 | 07:17 PM
matts95max's Avatar
torchem' til they are glowing atcha!!..well let the shop do it if you dont have any experience dont wantcha getting hurt or messin something up
Old Oct 11, 2006 | 08:27 PM
NmexMAX's Avatar
dot dot dot ...
I would probably engulf myself in flames trying to attempt that w/no jack stands.
Old Oct 11, 2006 | 08:29 PM
Apparition's Avatar
Ichiban King
MAPP GAS..
Old Oct 12, 2006 | 07:51 AM
ManualMaxima's Avatar
5th Gen till she dies!
I just took mine to a shop. they loosened them up for free. so I could go home and do what I had to do. just use stainless steel hardware when putting exhust parts back on
trasmadean
Feb 1, 2017 08:20 PM
Slamrod
Apr 10, 2016 05:24 PM
googus
Aug 19, 2015 04:42 PM
Mcnabb34
Aug 11, 2015 08:45 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
