Back up light switch / reverse switch
Old Oct 12, 2006 | 12:36 PM
Abimax95's Avatar
Hi there guys my car failed inspection because my reverse lights did not come on I checked the light bulbs and they are good , I did change the tranny from my 95 to a 96 does that make a difference on the plug ??? and one more thing ..were in the hell can I buy the damn thing nobody here has it or sell it I have to special order it .. any help will be appreciated ..
Old Oct 12, 2006 | 01:40 PM
Sounbwoy's Avatar
I have the same issue, except the reverse lights are not on the inspection list for NC. Two suggestions I have heard are:
1. Fuses
2. Transmission switch on the tranny case. I've been warned that the tranny should be drained b4 removing the switch. You may have to check with a dealer. Gwinnet Nissan is a good source. I have a 5-speed.
I'm assuming you have an automatic so if that's the case, I'm not sure how it looks on that.
Old Oct 13, 2006 | 05:46 AM
Abimax95's Avatar
Hi there Soundwoy thanks for the reply ..I do have a five speed and I know it is the switch at the tranny and yes drain the fluid or tilt the car in a way tha the left side is way up ..I google it and only one place came up that has it but I'm not sure if it is the same switch cause they call it neutral safty switch i can'y remember what the manual calls it ...I must warned you if you want to do it have the switch on hand cause it will break and make sure you grab the little copper thingy ..I have taken my tranny out so many time that i can do it with my eyes close ...
Thanks again .
Old Oct 13, 2006 | 06:01 AM
Sounbwoy's Avatar
Thanks. I checked the Gwinnet Nissan Website and they have a "backup switch" listed for $18.50. Go to http://www.nissanpart4u.com/oem_parts.html
Select year and make, then model. Then select ELECTRICAL, then CHASSIS ELECTRICAL then SWITCHES. It'll be the first item listed. I'll be getting one next week.
Old Oct 13, 2006 | 07:07 AM
Abimax95's Avatar
Thanks Soundwoy I just order it $30.00 shipped can't beat that ..
Thanks a million ....
Old Oct 13, 2006 | 09:14 AM
Sounbwoy's Avatar
let me know how it goes
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
spidgeon
Aug 18, 2015 05:46 AM
Derrick2k2SE
Aug 12, 2015 06:47 PM
kjm900r
Aug 5, 2015 07:14 AM
