Power Steering Problem
Old Oct 14, 2006 | 06:32 AM
bds's Avatar
bds
I have a 1999 GLE with 187, 000 miles. Recently flushed the power steering fluid.
Last winter when the temp in the garage was below 50 deg, I would lose my PS while backing out. I flushed the PS fluid and all was good through out the summer. Now that it’s getting cold again the problem is back.
When I back and turn The PS dies for a second and then comes back. When I turn the wheel the other way it happens again. From then on it seems to work fine for the rest of the day. Right now this is only a nuisance and I can live with it if it doesn’t get worse.
Any ideas on what’s causing this? Should I just live with this till it dies or fix it before it strands me??
Old Oct 15, 2006 | 05:48 AM
bds's Avatar
bds
anybody else have this problem
Old Oct 15, 2006 | 06:05 AM
matty's Avatar
Are you properly flushing the system ?? Getting the car up on jack stands and turning the wheels back and forth a bunch of times to get the air out ?
-matt
Old Oct 15, 2006 | 06:35 AM
MDeezy's Avatar
how old is that PS fluid thats in there?
Bleeding the system:
with the car in the air. Full turn to the right, Left, right, left.
with car on the repeat above.
Use new fluid.
Old Oct 15, 2006 | 07:01 AM
dgeesaman's Avatar
Maintenance Monster
Your PSP could be going out. You can get a decent low mileage used pump for around $50, but installing it is a minor pain. As long as the goofy stuff on cold mornings doesn't increase or get worse, I'd leave it alone.
Dave
Old Oct 15, 2006 | 07:33 AM
MDeezy's Avatar
installation can be a major pain. It wasnt as bad as I though putting mine back on, but with a careful eye it wont take too long. . .
but I had my y pipe and pass axle out, so that made it muuch easier.
Old Oct 15, 2006 | 07:55 AM
njmaxseltd's Avatar
Replace the PS drive belt, it's probably glazed and slips when it's cold.
Old Oct 15, 2006 | 12:29 PM
bds's Avatar
bds
Ill try this first, the belts are kinda old.
Old Oct 28, 2006 | 09:22 PM
Jatan's Avatar
Did you fix the prob?
Old Oct 31, 2006 | 09:16 PM
bds's Avatar
bds
Replaced the belts, took care of problem. I didnt realize that these belts need to be adjusted. no self tensioning.
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
coasterswim
Sep 2, 2015 07:43 AM
