Weekend Engine Cleaning
Old Oct 17, 2006 | 01:46 PM
  #41
moogotzskillz2's Avatar
thats good, that it stopd hissing or turnin off, take it for a spin around the block and see what it does?
Old Oct 17, 2006 | 06:14 PM
  #42
shadyonedeath's Avatar
Bump. i think im gona make a new thread, this title doesnt seem to get much attention.
Old Oct 18, 2006 | 04:26 AM
  #43
progun's Avatar
I was thinking about using Seafoam in the intake manifold to wash that stuff out. I am thinking that shady may have dirtied the aic valve with the washed off gunk. You should go to Harbor Freight and pick up a cheap torque wrench and look to the Haynes manual for torque specs. Be very cautious of bolts threaded into aluminum! You could also use a LIGHT coat of gasket sealant on the new gasket when you reinstall it. Send me an e-mail if you need me to look up anything for you. Paul
Old Dec 9, 2006 | 09:55 PM
  #44
RedBaronK's Avatar
Shady I am thinking about cleaning my TB and manifolds as well, did you finally fix the problems u had from the cleaning? please share how it all went. thx
Old Dec 10, 2006 | 02:17 AM
  #45
Buy a new IM gasket. You're going to need it.
and remember where everything goes...
Any other Q's, just ask.
Old Dec 10, 2006 | 06:58 AM
  #46
RedBaronK's Avatar
how much was the IM gasket? and did u get it from the dealer or auto store? since everything was put back together hows the car riding now? back to normal or better?
Old Dec 10, 2006 | 07:07 AM
  #47
MOHFpro90's Avatar
Is your idle still messed up? I had this same issue, and I fixed it. There is a hose, short, about 5 inches long, with a white plastic peice on the end. That snaps into a blue peice on the engine. Here is a pic. When I did this, I had a friend help me. He found the hissing, that hose, and pushed it on really tight, and that stopped the idling problem.
Pic:
Old Dec 10, 2006 | 09:26 AM
  #48
Apparition's Avatar
Ichiban King
That's Fr33way's old engine bay shot..
Old Dec 10, 2006 | 11:41 AM
  #49
About 20$ at kragen. If i would have replaced the gasket before assembling it back together, my car would probably be idling better right now. But i was dumb and forced it to start/stay on and that might have damaged something.
Shouldn't be a problem for you if you do it right the first time.
Pic:
Thanks, ill check that out, but what "idle" problem are you reffering to? I think it idles just fine right now.
Yea, he's aware...kthnxbye
MaxLife17
Jun 27, 2019 01:37 PM
6spd4dsc
Mar 4, 2016 05:19 PM
I<3 A32's
Sep 10, 2015 11:07 AM
MaxLife17
Sep 8, 2015 02:36 PM
