Altenators keep blowing!! Need help!!
Old Oct 16, 2006 | 07:07 AM
yevrah4728's Avatar
I'm on my 3rd altenator in 2 weeks (and it's only that long because i let the car sit for a week) I've tryed different tensions on the belt thinking maybe I over or under tightened but either way the same thing happens. It's good for about an hour then the voltage starts to drop(have a voltmeter function on my radio) and then the battery and brake light comes on. Has anyone had this this problem before? Does anyone know of somewhere I can get this checked out in or around canarsie/east flatbush area(brooklyn)? I'm tired of changing altenators anyone whose done it knows it's pain in the ****...Help please!!!!
Thanx guys, in advance.
PS. what is the alt.s fuse for? I was wondering because it's only a 7.5 amp and that seems kinda low for the altenator...
Old Oct 16, 2006 | 08:02 AM
Jesse729's Avatar
What kind of alternator did you buy? I know with some rebuilt ones they can be bad right out of the box. The place you buy them from can uaually test tehm before you buy them.
Old Oct 16, 2006 | 08:12 AM
matrix11229's Avatar
Probably the alternator is bad. What was the problem with the first two alternators ?
Old Oct 16, 2006 | 08:18 AM
yevrah4728's Avatar
I bought them from Autozone. I had them tested and they passed before installing them. When I take them out and go back they fail the same test they passed the day before...the same thing keeps happening over and over. I'm lost, I don't know what it is or what to do.
Old Oct 16, 2006 | 08:59 AM
df8888's Avatar
Have the battery checked. Bad battery can short altenators. Fuse is for the brake and battery light. Make sure battery is fully charged when you install new altenator.
Old Oct 16, 2006 | 05:06 PM
GKET36's Avatar
apparently autozone alt are no good the one i bought died in 1 wk 50 miles fr bklyn on taconic pkwy at 1:00 am any how if you hv an SE the alt output is 125 amps and theirs may not be. I ended up being towed to nissan dlr in peekskill(slept in car) and $475 later back on road with no problem since.
Old Oct 17, 2006 | 05:49 AM
Zero-K's Avatar
VQ30DET
I just went through this, I just bought another Max. This one was in an accident. I finally replaced all the parts to get it on the road but figured the battery was good enough(still held a charge no problem) after my altenator died, I figured it was just old, so I bought a new one, put it on and it died within 30 minutes, got warantee, put another one on and it blew in another 30 min, got warantee, and this time I was checking things to make sure I was getting correct voltages and managed to find that my battery shorted out and was feeding back through the ground. it was bad enough that it blew acid all over the inside of my car when the battery shorted out. changed the battery and haven't had a problem since.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Noela
Sep 26, 2015 08:22 AM
jwright36
Sep 8, 2015 11:45 AM
