Yet Another Misfire
Yet Another Misfire
So once again my 95 is misfiring again. this time i have a misfire on cylinder one. I put in a coil pack i had lying around and it didnt do anything to change the problem. I checked the codes again today and i had (0202) Ignition Signal Circuit. What does this pertain to. Any help will be greatly appreciated as i dont want to drive my car running like **** all winter
is the coil that you had laying around new? Correct me if I'm wrong, but I think Ignition Signal Circuit pertains to the coil. I got that code when I accidentally bent one of the pins on the harness to the coil. Had to straighten the pin back out, then reconnect it carefully. Take a multimeter and test it.
if that coilpack you tried was still in working condition, then id check all the wiring and also the injector. another way is to take out the coilpack and hook it up with a spark plug in it. crank the engine real quick and see if it sparks. if it does, then change the injector and see if it changes. hopefully it should.
brand new injector from dealership ~$160, installation ~$200, if its under the intake manifold: Cylinders 1,3,5. call your local shop for installation prices. and shop around for injectors from other venders.
jmlee44
10-02-2022 02:13 PM
ballerchris510
09-11-2015 05:29 PM
