shocks and struts
Old Oct 25, 2006 | 03:47 PM
ethnic6's Avatar
shocks and struts
I'm just looking for some new struts, and I saw these KYBs... how does these look? legit?
http://cgi.ebay.com/ebaymotors/KYB-G...QQcmdZViewItem
Old Oct 25, 2006 | 06:45 PM
Capital15's Avatar
I have KYB GR-2's on the back of my ride.....they ride pretty good. It looks legit. It is a good deal for all four under 200 bones.
Old Oct 25, 2006 | 11:46 PM
ethnic6's Avatar
What are the usual prices for Struts and Springs?
Old Oct 26, 2006 | 03:30 AM
d00df00d's Avatar
Old enuf to pick his own gears
Struts: $200-$550 a set
Springs: $150-$230 a set
$193.99 + $21.22 shipping for a set of GR-2s sounds about right. If you have stock springs, this will be a good deal for you. If you have lowering springs, look elsewhere.
Old Oct 26, 2006 | 04:03 AM
njmaxseltd's Avatar
GR-2's are a very stiff strut and will give a very firm ride.
If thats whay your looking for, then thats a good deal for you.
If your looking for more of a factory smooth ride, you need Tokico Blues.
Both a/m setups should be used on the factory springs.
Old Oct 26, 2006 | 04:16 AM
babymac's Avatar
BOOST 4 LIFE!
I have gr-2's on my eibachs and they are steadily going bad, so definitely look elsewhere if your lowering. I am saving up right now for some koni's!
Old Oct 26, 2006 | 07:26 AM
ethnic6's Avatar
I'm not looking to lower my car, I just want to improve the quality of the ride because its really bumpy, I literally feel every nook and cranny the road has to offer... just want to firm it up and not feel like i"m bouncing up and down everytime my car hits a bump or a small hole...
Old Oct 26, 2006 | 07:27 AM
ComradeJew's Avatar
I have Tokico Illuminas and Eibach springs - they are fantastic together.
Old Oct 26, 2006 | 10:40 AM
ethnic6's Avatar
how much did they run for?
Old Oct 26, 2006 | 01:11 PM
f550maranello2's Avatar
gr2's suck... are WAY to stiff
Old Oct 26, 2006 | 01:24 PM
LILMAN's Avatar
I just caught the same deal a month ago. They're legit
Good luck.
Old Oct 26, 2006 | 01:39 PM
ethnic6's Avatar
see I'm new to this whole suspensions game, so I'm just trying to find a good deal for struts, not sure exactly what stiff or the other terminology means, I guess I'm just use to feeling like a bobblehead inside my car and in my mind anything would be better than that...
Old Oct 26, 2006 | 02:09 PM
d00df00d's Avatar
Stiff means bumps hit hard when you drive over them.
GR-2s are a little firmer than stock struts, which means they communicate more of the impact when you hit a bump. It's sort of like having slightly stiffer springs. One thing to remember is that their reputation for being "stiff" mostly comes from when people use them with lowering springs. They just aren't built right for that, and end up giving a pretty jarring ride and wearing out pretty quickly. But as long as you're on stock springs, they'll be fine. They'll even improve your handling a little.
The "bobblehead" feeling you're getting is probably because your struts are worn. They're not controlling wheel motion like they should, so there's a lot of bounce in the suspension and you're getting knocked around. New struts will definitely fix that, whether they're OEM, KYB GR-2s, or Tokico HPs. OEMs will absorb bumps the best but give a floaty feeling; GR-2s are much more controlled but slightly harder-riding; HPs are a nice medium.
Old Oct 26, 2006 | 02:27 PM
nosispower's Avatar
I have GR-2s on my car with stock springs and I like the ride a lot. It's better than before because 1 of my struts were blown and the others had 110k miles of wear on them. The new ones are stiffer but the ride quality is still muuuch better than it was with my worn out struts.
You'll appreciate the more controlled ride and more responsive handling.
Stagnet04
Oct 11, 2015 08:16 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
