help w/ lowering rear of my 4th gen
Old Oct 26, 2006 | 08:36 AM
se_nismo's Avatar
hey guys i just lowered the front of my car with some lowering springs but in the rear i noticed that i cant use my spring compressors to clamp the oem spring down...so my question is do i need to clamp the rear oem springs? how do you guys do it?
thanks
Greg
Old Oct 26, 2006 | 08:43 AM
cruzer82's Avatar
before I bought my spring compressor I used to just put the spring/strut on the floor next to a wheel with to make sure it doesn't shoot towards me and blast the bolt off with impact gun.. the strut goes flying about 5 or 6 feet away..
When you go to put the lowering springs on you won't need to compress it... Just make sure you do it where it won't hit anyone or thing and bounce around.. do it on grass.... I know, I know, it's not the safest way but it works I did this on all four.. the fronts fly further.
Old Oct 26, 2006 | 08:48 AM
se_nismo's Avatar
thanks for the reply, i know the fronts have alot of tension but i wasnt sure of the rears being that they dont look as compressed as the fronts...if no one else has any other suggestions then im going to just let them pop
Old Oct 26, 2006 | 08:49 AM
MaximaSE96's Avatar
Maxima Owner
rears u dont need compressors...fronts i would never do without one
Old Oct 26, 2006 | 10:06 AM
njmaxseltd's Avatar
Rears are not under much preload at all. Just zip the nut off, you can hold the assembly down with just your body weight or let it fly off on the floor.
Finkle
Sep 27, 2015 09:53 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
