Tachometer Dead. New ECM ?
Old Oct 28, 2006 | 03:27 PM
shilov's Avatar
The tach on my 1996 SE was on and off ever since I bought it about a year ago. Recently I have installed a grounding kit and now the tachometer is dead all the time. I checked the connection from ECM terminal 5 to w/g wire at the gauge cluster and it was fine. Then I checked the voltage at terminal 5 when car was running and it was 0 ( ~7V at idle according to the manual). Does it mean I need a new ECM to fix this tach problem ???
Old Oct 28, 2006 | 04:58 PM
VGinMIA's Avatar
I replaced my tach when it began to fluctuate all over the place and it is fine now.
Old Oct 28, 2006 | 05:21 PM
shilov's Avatar
I don't think it the tach since there is no voltage on its input.
Old Oct 28, 2006 | 07:56 PM
BlackMaxdout's Avatar
it's the tach unit itself. Mine does the same thing. (96 SE) It bounces around all over the place, and hardly even readds correctly when it does work right. You should get between 0 and 5 volts total for the tach from the ECU, depending on RPM. Have you looked up tachometer units? Way too much $$$$$ for me to even bother replacing it...and there are no Maximas in the junkyards around here
Old Oct 29, 2006 | 06:25 PM
shilov's Avatar
That's the thing. It doesn't show any voltage on ECM terminal that's supposed to feed the tach.
aw11power
Oct 10, 2021 04:57 AM
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
markevans999
Sep 10, 2015 04:29 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
