Coolant Leak
Old 10-30-2006 | 01:16 AM
SupaFly831's Avatar
Coolant Leak
Yeah, I got a leak from the head gasket, near the UDP. What would be the best solution to this problem???
Old 10-30-2006 | 08:00 AM
moogotzskillz2's Avatar
i dunno if its from the head gasket? but i had the same problem on my 95 max.. and it was the Water pump going out, actually it was the seal, but if u goin to replace the seal u mmight go ahead and replace the water pump
-moo
Old 10-30-2006 | 08:06 AM
ManualMaxima's Avatar
5th Gen till she dies!
i just had the same problem and it was the seal on the thermostat. New thermostat form nissan and new gasket, ran $30 and it was good as new
Old 10-30-2006 | 01:44 PM
SupaFly831's Avatar
I replaced the thermostat last year with new gasket. The leak is down low by the oil pan. I can't replace the whole gasket cuz I don't have that kind of money right now. So what kind of sealers are out there for this?
Old 10-30-2006 | 03:55 PM
njmaxseltd's Avatar
The head gasket is nowhere near your UDP.
Thats not where the coolant is coming from.
Old 10-31-2006 | 05:03 AM
SupaFly831's Avatar
Well what gasket sticks out down there?
Old 10-31-2006 | 02:20 PM
mountain people's Avatar
if you have a blown head gasket, you would be smoking white, rite? check your oil to see if you got coolant in there.
Old 10-31-2006 | 02:50 PM
konak85's Avatar
its either water pump or thermo
Old 11-03-2006 | 06:03 AM
SupaFly831's Avatar
Haven't checked the oil yet, but the last like 4 times I changed it it reeked of gasoline. Wuts up with that???
Old 11-03-2006 | 04:46 PM
'96 B-rad's Avatar
I think this its around the gasket where i was leaking and it turned out to be a hole in the coolant line bracket (thats what guy called it) it ran me $320 since I went to pep boys but they did also order the part from nissan.
Old 11-04-2006 | 12:09 AM
How much coolant are you losing? DO you have white smoke coming out of your tail pipe?
Anyway, has anyone used this so-called steel seal for blown head gasket?
www.steelseal.com
Old 11-04-2006 | 07:27 PM
1996blackmax's Avatar
If it seems that it's coming from around the timing chain cover area and running down to your oil pan it is probably your water pump. Mine did the same thing...
Old 11-04-2006 | 07:43 PM
shadyonedeath's Avatar
Mine does that...like right now.
Did you fix it yourself? How much did it run you$?
Old 11-05-2006 | 04:58 AM
I was going to tackle it myself. I then began reading about it here, asking some questions, and thought it would be better to let a shop do it. I got several quotes ranging from $250 dollars all the way up to $700 dollars. One of the less expensive shops was almost arguing with me telling me that my car had a timing belt and not a chain..... skipped that one pretty quickly. I ended up going to the dealership and paying $550 dollars to get it done.
Old 11-05-2006 | 10:46 AM
AndyGXE95's Avatar
I just found out my car is leaking coolant too.
Old 11-06-2006 | 11:48 AM
cam_honestiam's Avatar
When mine was leaking coolant, I changed the Water Pump and seals, as well as the thermostat. The leak persisted and I realized it was coming from a warped metal gasket where the inlet/outlet pipes connect to the engine block. The pipes are tough to remove due to bolt position, but the leaky gasket was allowing a pinhole spray directly into my alternator. The leak also trickled down by the oil pan. At first, all indications pointed to water pump. I was wrong.
TO FIX:
Clean the entire area. Put car up on jacks (or a lift) then run your engine to operate temp and monitor where the leak is originating from.
litch
123
01-04-2024 08:01 PM
aw11power
10-10-2021 05:57 AM
Miket2006
03-01-2021 04:55 AM
foodmanry
09-24-2015 01:02 PM
Hdnseek
09-09-2015 06:55 AM
