air bags
Old Oct 31, 2006 | 06:57 PM
GStrength's Avatar
air bags
what's the difficulty in replacing the air bags yourself is it even possible?
Old Oct 31, 2006 | 08:31 PM
nsnrider's Avatar
It takes about 30-45 minutes depending how knowledgable you are on maxs'. The driver airbag is a piece of cake, the passanger airbag is a bit tricky. You will nee the security key set found at sears. (maybe other stores as well).
Old Nov 7, 2006 | 12:26 PM
hotimportnight9's Avatar
after you remove the scurity bolt it says u have to put on some type of new ahesive is that true or could u just put the screw back in?
Old Nov 7, 2006 | 01:03 PM
Dubbya's Avatar
VK56 Inside
You should just use some loctite on the security bolt. Thats pretty much what is on there to begin with.
Old Nov 7, 2006 | 02:02 PM
bigballa97
My question is, do you need a new air bag module if both of the air bags have deployed?
Old Nov 9, 2006 | 07:15 PM
bigballa97
BUMP^^^ i dont want to start a new thread about airbags!! anybody?
Old Nov 9, 2006 | 07:24 PM
CRiME's Avatar
oem ftw!
yes you do. modules can only be used once
Old Nov 9, 2006 | 07:26 PM
bigballa97
awesome thank you, just wanted to make sure cause i had my friend change his.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Garrettz459
Sep 28, 2015 02:50 PM
