Replaced MAF after 160k miles...what a difference!
Old Oct 31, 2006 | 08:30 PM
black97's Avatar
i was getting sluggish acceleration since i bought the car, even though i didn't have any codes of ECU. So today i finally spent time on replacing MAF (i've had one in my garage for a long time of the newer maxima but never thought about changing it as mine was working fine.....) anyways when i started the car and gave it some throtlle.... holy that was a big difference!! Now car feels jumpy and i get acceleration at all rpm range. I actually enjoy driving it again.
Just decided that my post could be helpfull to someone.
Old Oct 31, 2006 | 08:55 PM
Mxrider52's Avatar
I support for what?
MAF cleaner would have probably done the trick.
Old Oct 31, 2006 | 08:57 PM
heynow's Avatar
where do you get the MAF cleaner, and what brand?
Old Oct 31, 2006 | 09:00 PM
99grnmaxgxe's Avatar
He had one laying in his garage, you can get one from the Classifieds section.
Old Oct 31, 2006 | 09:15 PM
Mxrider52's Avatar
I support for what?
Can buy it at advance auto parts. Possibly other places to.
Old Oct 31, 2006 | 09:29 PM
Apparition's Avatar
Ichiban King
lol @ the HP increase.. even though that could be true in some cases I guess.
Old Oct 31, 2006 | 10:05 PM
Godson's Avatar
Im lovin the HP increase. I would hope my MAF was never that bad to need 10hp restored to it...
Old Oct 31, 2006 | 10:49 PM
Max Noob's Avatar
could i just clean with a qtip and alcohol?
Old Oct 31, 2006 | 10:58 PM
l3ftonm3's Avatar
no get the MAF cleaner and do it right, if you mess the sensitive sensor up your out 60 bucks rather than 4 for the can.
Old Oct 31, 2006 | 10:59 PM
mastercater7's Avatar
VQ35 FTW
could a bad maf drop your gas mileage?
Old Nov 1, 2006 | 04:56 AM
MaximaSE96's Avatar
Maxima Owner
hmmmmm.....yes and no....depends on what the malfunction is......the maf basically tells the ECU how much fuel to send so if its reading less air cause of malfunction then ur actually leaning it out...but if its reading more air than its really going thru again cause of malfunction then it would send more fuel..........
Old Nov 1, 2006 | 09:05 AM
maxedoutboi06's Avatar
I guess thats why my maxima has been kinda sluggish, I can get an MAF cleaner at Advanced Auto parts? How much?
Old Nov 1, 2006 | 10:05 AM
heynow's Avatar
Thanks dude!
Old Nov 1, 2006 | 01:32 PM
gx2nds4's Avatar
awesome, now i'm going to clean my maf and throttle body when i get the chance.
Old Nov 1, 2006 | 03:49 PM
Fr33way™'s Avatar
Wild for Width
Don't count your eggs just yet.
Old Nov 1, 2006 | 05:13 PM
Apparition's Avatar
Ichiban King
..its not easter yet.
Old Nov 1, 2006 | 05:53 PM
matrix11229's Avatar
I used it but I don't feel any difference at all. I have no CEL and the car accelerates fine (I guess) - I never drived another maxima so I'm not sure.
But my gas mileage is horrible (13mpg or 200 miles per tank, all city) and I never rev over 2500rpm.
I heard some .org members replaced their MAF and had imrovement in gas mileage.
Is replasing the MAF will improve gas mileage even if I have no cel ?
Old Nov 1, 2006 | 06:49 PM
shadyonedeath's Avatar
$6.48 10bars
Old Nov 1, 2006 | 09:43 PM
ganslee's Avatar
For this you may want to consider replacing your O2 sensors... Especially if you tend to notice a strong fuel smell. This can cause the car to run rich and get bad gas mileage as well as run poorly, loss of acceleration etc.
Old Nov 1, 2006 | 10:19 PM
Since I bought this car in June (with 189k miles) I replaced all O2 sensors, knock sensor, spark plugs, oil, coolant temp sensor, pcv, fuel filter, air filter, cleaned throttle body, used lucas injector cleaner and maf cleaner, seafoamed in brake booster line and crank case.
After all these replacements the performance was increased but there is almost no change in gas mileage.
There is no gas smell
Old Nov 1, 2006 | 10:57 PM
VQ35 FTW
a bad knock sensor would drive gas mileage from 360 a tank to 250 a tank correct?
Old Nov 2, 2006 | 10:32 AM
maxfanfromohio's Avatar
Shiver me timbers.
Yes it could.
Old Nov 2, 2006 | 11:33 AM
heynow's Avatar
same here dude
Old Nov 2, 2006 | 07:37 PM
ganslee's Avatar
Have you checked the injectors? If you have a leaky injector (carbon deposits and such can cause them to hang open), that could also explain a gas mileage problem.
It's worth a look if you haven't already checked.
Old Nov 2, 2006 | 08:06 PM
Cleaned it today with that stuff^^.
Didnt notice anything, if anything its slower. But thats maybe because i was tinkering with with EGRC solenoid valves and cleaned/sanded the knock sensor bottom.
Old Nov 2, 2006 | 10:23 PM
No, I didn't check the injectors yet. I thought I will have CEL if they are bad or I would feel hesitations or rough idle.
How do you check them ?
jskirwin
Jun 8, 2016 08:49 AM
vingodine
45
May 21, 2016 12:46 PM
PH98I30
Aug 20, 2015 04:25 PM
MikesChevelle
Aug 10, 2015 10:53 AM
