ECU Question
Old Nov 2, 2006 | 06:38 AM
ILLeSt MaX's Avatar
ECU Question
I dont know if you guys remember that I started a threard about my damaged ECU about a couple weeks ago.. Well my CEL came back on AGAIN!! Im the one that did the self diagnosis test and took it past stop... Well, i did the self test again and it came with code 0503, 0304, then..... 0505... The codes are Front Right heated 2 sensor.. Which I just got replaced like 3 weeks ago. Knock sensor.. Which I thought trips when o2 sensor trips.. then 0505 is no failure detected... How does that make sense?? Is it because I messed up my ECU? Cuz instead of goin clockwise and counter-clockwise, I had to just find a spot just to reset the ECU... So im guess its really messed up. Would this ECU from ebay be a good replacement??
http://cgi.ebay.com/ebaymotors/96-Ni...spagenameZWDVW
help..... im in desperate need of help! o yeah, i have a 96 auto
Old Nov 2, 2006 | 08:37 AM
ILLeSt MaX's Avatar
..... any help?
Old Nov 2, 2006 | 09:23 AM
eng92's Avatar
See if you can find out the p/n to verify that it is out of a 96-auto.
Should be something like:
A18-C85-EY1
A18-C85-EX9
A18-E66-EZB
There are a few others.
Old Nov 2, 2006 | 12:16 PM
ILLeSt MaX's Avatar
thanxx... ill check into it
Old Nov 3, 2006 | 06:20 AM
ILLeSt MaX's Avatar
this is what the guy responded back to me with...
"Hello,
The part number is hard to read due to being worn. The numbers that I can read are as follows, A18-C85-CX9???. That is all I can make out. The VIN is JN1CA21D6TT160168. Hope this helps. Thanks for looking. Rod"
Old Nov 3, 2006 | 07:58 AM
eng92's Avatar
That should be A18-C85-EX9.
That VIN is for a 96 GLE with AT manufactured 02/96.
You should have no problems with that ecu assuming it was working when it was removed from the donor car.
Old Nov 3, 2006 | 10:09 AM
ILLeSt MaX's Avatar
Thanx alot... i appreciate the help u provided.. u dont understand, my CEL has been comin on constantly for the past 2 years.. I always replaced the part that threw the code off, but it always came back.. Hope I can get it fixed..
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
