preventitive steps when going dino to syn ATF
Old Nov 2, 2006 | 06:37 PM
kbmaxima's Avatar
the last thing I need is fluid leaking after dropping loot on a case of amsoil. I am planning on changing the axle seals while filling up with new synth. any other seals present that I should replace while I'm there?
in regards to the drain/fill, no matter how well it's done, won't there still be a mixture of a little dino and synth fluid? What would be the most optimal method for a 110K tranny? planning on dropping the pan, just don't see how one could get all the dino fluid out.
Old Nov 2, 2006 | 07:08 PM
kcryan's Avatar
mabye auto-rx her first?
Just what i would do...
Old Nov 2, 2006 | 08:06 PM
dgeesaman's Avatar
Maintenance Monster
If you're worried about leaks, why are you changing to synthetic?
I would just put in clean dino ATF.
Dave
Old Nov 2, 2006 | 08:50 PM
CRiME's Avatar
oem ftw!
When i converted to mobil1 synth a few months ago, I did the self-flush, as outlined in the fluids and lubricants stickes: http://forums.maxima.org/showthread.php?t=149056
I've had no leaks or ill effects. The transmission feels great. My car has 131k. I'd recommend that process as you get just about all of the old fluid out. If you do the simple drain and refill, you'll still have i think over 4 quarts of old fluid in the system
Old Nov 2, 2006 | 08:58 PM
kbmaxima's Avatar
Dave
the added benefit of a longer drain interval and cooler running temps. i'm going to change the pan gasket, and axle seals (still cant find part #'s), just making sure I'm touching all bases.
gigabyte
Jan 6, 2017 06:05 PM
JoshG
51
Sep 21, 2015 10:41 PM
thenewguyy
Sep 12, 2015 11:12 AM
