Help! Car Wont...
Help! Car Wont...
well ive been having this problem for quite a while now pretty much ever since i bought the car but didnt really get bugged out about it till NOW!! It doesn't happen that often but a few times every other day or what not. Basically it'll keep on turning, but it wont turn over. The 2nd or 3rd try it'll start. Ive changed the starter and battery about 45k miles ago, and just recently put in a new alternator. What other parts should i be watching?? Basically all i've got is an Injen CAI. There are no codes poppin up whatsoever. Could it be the starter again? Could something be clogged? Just list all of the parts that i should clean out and that i should be on a look out for, for being clogged. Iv'e also been reading about the Seafoam stuff, would that help me out in anyway? I've got almost 105k miles and it is my daily driver. As i said i have'nt changed any parts other than what is listed above.
Thanks,
-Ali
Thanks,
-Ali
If the starter spins the ring gear properly, it's not ignition switch/starter. No codes? If you're at 105k miles on the original, I'd replace the fuel filter. It led to eliminate overnight hard starts for me, as well as bogging down when it's at less than a 1/4 tank.
Does this just happen on a cold start or when it's sat for a while? Or even if you turn it off then try to start it back up right away? Fuel filter is cheap, try that first.
after i got a complete tune-up at 55k miles, ive changed the feul filter 3-4 times till now. Yes it does happen at cold starts to, but check this out. After i drive it for about 30-45 mins, and i let it sit for 30 mins or so...it'll do the same thing.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
