The bolt that holds the 1.5in plug in tranny
Does anyone know the bolt size or the part number for the bolt that goes into the 1.5in plug on the bottom of the tranny? I think it is called the gear selector sensor or something like that? All that is left of my clutch job is to put that back in and fill the tranny back up but somewhere along the line I lost just that bolt.
??? The tranny is already drained. In the process of doing my clutch I lost the bolt that holds that plastic plug in place and so I can't finish until I can get it replaced in order to put the oil back in the tranny.
1) That is not a plug. That is a sensor. They get very brittle and if you use it as a drain plug you need to be aware that it can and will break.
2) You need any common bolt with a 10mm head. The threads are like 12mm long. The threads themselves might be M4.
Dave
Dave
Dave
Dave
ag90fox
Sep 9, 2015 12:22 PM
pktaske
Sep 4, 2015 08:40 AM
