Tire size (Dont Kill Me)
I know this has been asked before. So before anyone says it but.
Will 235's fit on the SE 5-spokes without rubbing excessivly. If they only rub at full lock on a revers J-turn then itll be ok. But if they rub in parking lot manuvers it will be a problem.
Thanks for the help,
Ricky
Ricky
If you're autocrossing, it would be just about perfect. But pretty much anything else I wouldn't do it even if it didn't rub.
Another really easy check is to see if you have at least 1/2" all around the tire at full lock. Mine rubbed a little bit with 225s, so I'm guessing the answer is no.
Well even 235's are questionable on the 5th gen 17x7. Considerings we have 16x6.5 i wouldn't try it for street driving. I personally wouldn't go bigger then 225, if you need to go bigger get wider rims.
Originally Posted by MaximaSE96
on a 6.5" rim its pushing it....on a 7" rim its perfectly fine.....i pushed 245s on a 7" rim
06-06-2017 02:01 PM
