dek motor in a 98...how hard
Create From Nothing
ok my motor died today (literally, today). ive been looking at replacements. how hard is to to put in the 00\01 vq30de in a 98 5-spd and are there any problems with the check engine light, tubes, TB, etc that I should know about before buying the motor??? or should I find the lowest mileage 95-99 vq that I can find???
Under the radar
depends on what your looking for... id say personally for my self id look for a 00-01 motor. less miles and more power. im not to versed on this topic but im pretty sure that the engines in the 95-99 are about the same as the 00-01.
Create From Nothing
at first I didn't know, but me and my co-worker had been talking and we came up with a theory. I killed the temper on the block. take a hot piece of metal (engine block), drop it into something cold (big *** puddle of water), and it will weaken the metal, to the point where it will crack.
the car car got flooded last thursay, i had been driving out in the rain all day. hydro-planed into a 2 foot deep puddle of water. with a lowered suspension i knew i was running into trouble. flooded the engine, and interior. 2 coil packs went bad other than that i thought i was fine. pulling off from a toll booth i hear a large bang, pull over oil all over the ground...a tow, $80, and 2 hours later my mechanic says that the engine is blown. ohh and 106,000 miles
damn, the puddles are taking everyone out...wasn't there another guy a week or so ago that had a similar problem (dgeeseman?), but didn't blow the motor? If you're not going to heavily modify the car and just want it to cart yourself around, just get a 95-99 motor....I feel you'd get less headaches with a direct swap. But then again, if a 00 engine is a direct swap too, go for that due to the higher likelihood of lower miles on available engines.
Create From Nothing
Originally Posted by 97Maximus
why dont you just get a vq35.. or just get another 3.0 and do a VI swap..
That was a DE for that price ?? I got a DEK out of a 01' earlier this year for $690 picked up with 8557 miles with a 6 month warentee. Keep looking and dont get anything over 15K miles in my mind. They are out there just keep making phone calls till you find one.
The dek is a fairly direct swap in with some little changes. Get yourself an IACV plate, flywheel, clutch and youll be pretty much set.
Originally Posted by 95mtlMAXSE
What does the IACV Plate do(apart from removing the IACV)
what is an rpm switch and what does it do?
So this adds power??? THe IACV is not completly eliminated??
-matt
matty,
I try to stay updated on swap info so I kind of have an idea on what to do when I change my engine. I have read that you recently swapped to a dek. Is there a write-up similar to the 3.5 swap for swapping a dek into a fourth gen? I know there are scattered threads containing information about their dek swaps, but it would be nice if there was one thread for dek swaps containing all of the parts someone would need to buy, what components(sensors,alt.,starter...etc) stay and which ones get thrown out, and any other information needed to swap other than removing the de engine and dropping in the dek. Do you know anyone that wouldn't mind doing a write-up?
Also, something was mentioned above about a 3.5 swap. Do you know if the cam adapter/spacer issue has been resolved.
Sorry to hijack.
Sorry to hijack.
Originally Posted by QnzMax
Holy crap! Where did you get that motor from? Im in the process of doing a DE-K swap and I'm looking for a 01 motor. Thats a crazy good price with amazing mileage.
When you buying a low mileage motor what I did and what I think should people should do is get the VIN #. Run it through carfax and get a mileage on there. Ask the Salvage yard to get the ESN# off the block. (located underneath the TB kinda on that rear back slanting back towards the Firewall) Then Call up Nissan USA, phone number found on website, and confirm that that VIN# matches the ESN# on the block.
As for me, all the number matched up for 8,557 miles and the motor was sitting in-doors for 4 1/2 years.
-matt
Create From Nothing
Originally Posted by whitemax21
matty,
Sorry to hijack.
Sorry to hijack.
Create From Nothing
Having an IACV on your 00VI setup is good for start up issued and idle issues. To me its a must if your useing a 00VI/DEK
-matt
-matt
Create From Nothing
needed parts
1. vq30dek
2. IACV plate
3. RPM switch
sensors from de to dek
1. bell housing
2. cam position
3. throttle position sensor
4. coolant log sensor
extra work
1. jb weld swirl valves (maybe)
2. swap evap system
3. rewire fuel injectors
i heard that you should swap all of the sensors from the de to the dek is that true??? ohh does anyone know the part numbers for the updated 5th gen coil packs???
1. vq30dek
2. IACV plate
3. RPM switch
1. bell housing
2. cam position
extra work
2. swap evap system
well I just finished my 2nd dek swap yday. I got a motor at a yard in SC and had it shipped to me. It is a 2000 fed spec engine with 120 actual miles! I paied $650 for it and $100 for shipping. $750 total. I called lots of places and some of them told me 50k miles was low and really good! haha I just said thanks an hung up! I will do a write up today or tomorrow. I have a 95 so I dont have evap. I used my flywheel, I just got it resurfaced. I got a new clutch and starter. with the 5th gen tb I cant hook up the egr correctly. So I am getting an adapter plate for the 4th gen tb from stephenmax to solve this. I kept the cps sensor on the dek by the timing case but swapped the sensor on the block/bellhousing with mine from my de because my ecu didnt read the one from the dek. I dont have an rpm switch yet. I am going to get a vafc2 and lc 1 to tune and use the vafc2 as my rpm switch too. I have a full 2.5 inch exhaust and am blaming that for my backfire out the muffler so that is y im going to tune.
Create From Nothing
AaronL
08-08-2020 10:31 AM
06-06-2017 02:01 PM
hayne
10-05-2015 11:53 AM
fx4five
10-01-2015 04:58 AM
