left headlight doesn't work and can't figure it out
Nov 25, 2006 | 01:48 PM
Alright, well my drivers side headlight went out last night randomly. It's not the bulbs, and it's not the Left or right headlight fuse. All my wiring seems fine and for the life of me I can't figure out why it won't work. I'm resetting my computer right now but I doubt that will do anything. my fogs and parking lights and turn signals all still work. Now my brights indicator in the gauges is on all the time when my headlights are turned on. Anyone have any clue on why this would be happening?
Nov 25, 2006 | 04:06 PM
I have heard if your high beam light is on in the dash,you probably bought 9007's instead of 9004's, if I remember correctly
Nov 25, 2006 | 07:25 PM
I'm betting it's the headlight switch that has failed...
if it is, you have to remove the steering wheel and airbag to change it.
good luck.
Nov 25, 2006 | 07:59 PM
good luck.
could it really be the headlight switch if my passenger side headlight still works?
Nov 25, 2006 | 09:12 PM
OT: if just the switch has failed, i dont think you have to take off the steering wheel and airbag, i've replaced on you just have to take off the stuff around the steering column and the piece of dash below the steering column which is all pretty easy
Nov 25, 2006 | 10:05 PM
well I think I figured it out. I checked the plug that connects to the bulbs and it looks like it's the connector. I'll post up a pic tomorrow to show what I'm talking about. Now I have to get a new one somehow and install it.
Nov 25, 2006 | 10:54 PM
I actually had the same thing happen twice... I just switched my bulbs around and it worked for me ... weird ... good luck
Nov 25, 2006 | 11:19 PM
Quote: I actually had the same thing happen twice... I just switched my bulbs around and it worked for me ... weird ... good luck
ya it's weird that it happened out of no where. I've switched around 3 different bulbs and nothing works.
Nov 26, 2006 | 05:09 PM
Quote: ya it's weird that it happened out of no where. I've switched around 3 different bulbs and nothing works.
Is it a regular bulb or cool blue or other white bulbs? If something other than the regular bulb, it may be burning out the socket each time.
Nov 27, 2006 | 12:05 AM
Quote: Is it a regular bulb or cool blue or other white bulbs? If something other than the regular bulb, it may be burning out the socket each time.
Nope regular bulbs. It's Sylvania xtravisions. I went ricer and went and bought silverstars and they also don't work
Dec 4, 2006 | 02:52 PM
Check the plugins they will melt under higher then normal headlight amp draw,and then insulate the bulb.If that the case replace w/hi temp and do a rewire w/relays to avoid voltage drop.
