How to take off headlights??
Old Nov 28, 2006 | 03:44 PM
Mymax97's Avatar
Hi
How do you unbolt the headlights from the car. Im trying to install the 1 pc headlights but cant figure it out.
Old Nov 28, 2006 | 04:36 PM
Cdg2125's Avatar
Four bolts. Two on the side and two on the inside of the light (next to radiator). That's it. The inner ones are a b!tch to get at tho.
Old Nov 28, 2006 | 09:31 PM
Mymax97's Avatar
Hi
yea that was the hardest part finding the bolts. Thanks for the reply.
Old Nov 28, 2006 | 10:15 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
I"m planning on installing my recently bought cefiros ... so if you could PM me on how you went about it ... that would be helpful thanx a lot man ....
Old Nov 29, 2006 | 12:47 AM
nguyen925's Avatar
dont you have to do some minor modifications to the fender in order for the cefiros to fit?
Old Nov 29, 2006 | 10:10 AM
Cdg2125's Avatar
I believe they do need to be trimmed and you need to get some weatherstripping. Mymax97 was putting on the new 1 piece. Not the cefiros.
Old Nov 30, 2006 | 06:41 PM
mrbill's Avatar
Wow.. What luck.. I think. Just yesterday I was trying to remove the headlight assembly and gave up. Found and and removed the four bolts you referred to and the tab that attaches the assembly to the grill. But the assembly still would not budge. Am I missing something or does it just need to be worked loose? My luck I'm gonna break something.
Thanks.
Old Nov 30, 2006 | 07:04 PM
Cdg2125's Avatar
You probably need to work it loose. First time I did it the bolts bent and wouldnt come straight out of the holes. I had to bend them straight. Other than the bolts and the grille they should come out fairly easily.
Old Nov 30, 2006 | 08:34 PM
|Bijan|'s Avatar
UCF Lexus
spray wd40 on the headlight and pull forward
Old Nov 30, 2006 | 08:49 PM
Cutler's Avatar
plasma cutter will take them out.....
Old Nov 30, 2006 | 09:47 PM
Skiptronic's Avatar
****. I cut a little too deep with my plasma cutter. Anyone have any front end parts I can buy?
Old Nov 30, 2006 | 10:31 PM
maxima_kenny96's Avatar
*holds up hand with 3 fingers*
Yeah, that works great
Old Nov 30, 2006 | 10:32 PM
Fr33way™'s Avatar
Wild for Width
This is always my 1st attempt for everything.
Old Nov 30, 2006 | 10:34 PM
its 1:30 am so my brain isnt functioning properly but can you really pull forward cause wouldnt that be pushing?
Old Nov 30, 2006 | 10:40 PM
Fr33way™'s Avatar
Wild for Width
Spraying WD-40 on something does not remove it so does it really matter?
Old Nov 30, 2006 | 11:03 PM
D-Bo's Avatar
Droppin logs
Be sure to check your blinker fluid while the headlights are out.
Old Nov 30, 2006 | 11:13 PM
Fr33way™'s Avatar
Wild for Width
Are you supposed to run synthetic with a boosted setup?
Old Dec 1, 2006 | 02:12 AM
Turbo1er's Avatar
Doin' it 4 da shorteez
Dont forget the headlight fluid. That is the extra tube you may notice from the CAI install.
Or any intake install. The extra hose connects to the headlight fluid.
Old Dec 1, 2006 | 06:42 AM
Dreizehn's Avatar
Make sure you replace or at least grease the headlight bearings while you've got the light out.
Old Dec 1, 2006 | 07:16 AM
Blaxxxima's Avatar
!OG SNES OG!
NEVER remove the headlights without tightening the Johnson rods first.
Old Dec 1, 2006 | 07:24 AM
dmBK's Avatar
How 'bout them cliffs?
you can get everything you need here:
http://www.kalecoauto.com/
Old Dec 1, 2006 | 08:55 AM
Vaudeville Villain's Avatar
For the easiest removal, you really should detach the front bumper. And take the radiator off.
Old Dec 1, 2006 | 09:04 AM
Kevlo911's Avatar
Kevlo for President
Mine were welded in! Imagine doing a retro with the headlights still in the car!
Old Dec 1, 2006 | 03:43 PM
RA030726's Avatar
I'm nutty for Nissans
My headlights were installed with left handed metric phillips screws. Where can I get the proper tool?
Old Dec 1, 2006 | 08:52 PM
Fr33way™'s Avatar
Wild for Width
I drive with my lights off sometimes just to ensure that I can delay this in-depth installation as long as possible. Guys that had a shop do it: did you need to get your car towed?
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
