Waterpump going bad? Vid inside
Old Nov 28, 2006 | 05:57 PM
motocross416's Avatar
I'm getting a kind of humming/whistling noise from the timing chain area. The belts are new and have the correct tension. All bearings on the alternator, compressor etc are good. I also found a bit of coolant on the garage floor the other day. From searching it seems to be the water pump but I wanted to check with the org for confirmation.
Here is a vid of the sound, It does not go away when revved, When I turn off the radio, I can hear the whistle while driving.
Clicky
Old Nov 28, 2006 | 07:25 PM
matty's Avatar
That sounds terrible man. How many miles on the motor ??
-matt
Old Nov 28, 2006 | 08:01 PM
JwaxMax99's Avatar
Oh, not good. A bearing likely is wiped out.
Old Nov 28, 2006 | 08:42 PM
Mxrider52's Avatar
I support for what?
That is definately not good. Sounds like a bearing like said above.
Old Nov 28, 2006 | 08:45 PM
AlpineGt66's Avatar
time for a VQ3.5 swap!
Old Nov 29, 2006 | 06:13 AM
motor has 147,000mi on it.
Any ideas on what it might be? Power feels fine right now and like I said its losing a bit of coolant. In about 150mi the resivor bottle went from the full line to the empty line. Temp gauge stays right in the middle position on the dash
Old Nov 29, 2006 | 07:19 AM
icedout's Avatar
that **** sounds like a vacum cleaner lol..time for a 3.5 i think
Old Nov 29, 2006 | 08:27 AM
heynow's Avatar
Does anyone else see the need to get a 3.5 instead of replacing a water pump?
Old Nov 29, 2006 | 01:36 PM
Sounbwoy's Avatar
I listened as carefully as I could. That sounds more like a fan than something mechanical. I say this b/c at cold start with my car, I'll hear something similar, but not as loud. It also happens with my wife's '99 325i- and then the noise will go away after about 30 to 45 seconds.
My theory is that it's more emissions related (o2 sensors or cats preheated)-I dunno. But I would think a waterpump noise would have a more mechanical sound.
Old Nov 29, 2006 | 03:05 PM
f550maranello2's Avatar
seriously stfu about the 3.5.. my god is a crap motor anyways...
Old Nov 29, 2006 | 04:02 PM
Thats what I thought when I first popped the hood, that is was the fans. But upon closer inspection the sound is definitely coming from the timing chain area.
Has anyone that had their waterpump go and had similar sounds to this? OR is this sound something unrelated to the waterpump?
Old Nov 29, 2006 | 04:57 PM
ProjectMax96's Avatar
ya, def. change the waterpump. I waited so long to change mine and i ****ed my whole car up, ended up running me almost a grand
Old Dec 6, 2006 | 02:18 PM
Update.
Pulled off the access hole to the waterpump and its not the waterpump, the sound is coming from somewhere further in the engine. So at this point, I guess I'm just going to drive it and hopefully it will make it till spring, then I'll see what to do about where to 3.5 it or just put another vq30 in.
Old Dec 6, 2006 | 02:37 PM
Apparition's Avatar
Ichiban King
The power is nice though.
Old Dec 6, 2006 | 03:26 PM
yea thats the only nice thing about it... buddy works at nissan says they get 3 or 4 a week for burning oil and headgaskets... under 60k miles!!!!
Old Dec 6, 2006 | 04:06 PM
Apparition's Avatar
Ichiban King
I actually deleted that part out of my post. They burn oil like crazy and a catch can is a neccesity IMO.
Old Dec 6, 2006 | 04:08 PM
matty's Avatar
Thats the reason why there isnt a 3.5 in my car. Also the reason why Im not buying a G35 right away
-matt
Old Dec 6, 2006 | 04:16 PM
werd the worst part is that is that the sentras and altimas are having the same problems....
Old Dec 6, 2006 | 05:10 PM
scrhale's Avatar
I didn't know the 3.5 was declared as a crap motor. The two times that I said "oil leak" in all-motor, every swore it was just isolated cases.
Old Dec 6, 2006 | 06:48 PM
Apparition's Avatar
Ichiban King
Isolated my @ss..
Two friends, one has an '02 6MT and another has an '04 6MT and both of them have had oil problems.
I had a friend with an '06 G35 Sedan though and I didn't see a single problem.
Old Dec 6, 2006 | 07:11 PM
matts95max's Avatar
friend of mine with an 06 350z is burnin oil and another friend has a spare 3.5 with a blown head gasket. That is why I went the de-k route when I swapped. Reliable, cheaper, and easier. atleast in my case
Old Dec 6, 2006 | 07:17 PM
nismology's Avatar
What's YOUR problem?
Old Dec 6, 2006 | 07:22 PM
nismology's Avatar
The 2005 VQ35 i bought isn't burning oil in the slightest. Nothing but carbon on the pistons like any VQ30 piston i've seen. I'll enjoy the added TQ, with trick stock features like an oil cooler and piston oil squirters. The VTC's won't hurt either.
FWIW, most VQ35's do NOT burn oil. You just hear about everyone that is. People that have a perfectly fine motor don't make special threads or take their car to the dealer saying how well their motor is running.
Old Dec 6, 2006 | 07:28 PM
nismology's Avatar
Oh yea...nissan-on-nissan hate is .
Old Dec 6, 2006 | 10:19 PM
no crappy engineering of 3.5 liter motors is gay....
Old Dec 7, 2006 | 04:25 AM
nismology's Avatar
OK, obviously you have nothing intellegent to say here. I'll move on.
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
chisam14
Nov 6, 2018 08:56 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
