So, I broke my car.
So, I broke my car.
Today I went out and bought a can of the CRC Electronic Cleaner and CRC Throttle Body Cleaner. I went ahead and cleaned both the MAF sensor and the TB as per the writeups on here and motorvate.
Now, the car starts and idles perfectly, but anytime I go WOT or close to it there is absolutley no fuel being added, as I can hear a ridiculous amount of air being sucked in (CAI) but there is no torque whatsoever. Also, in second and third gear when I go WOT the car rocks from front to back, similar to what it will do if you suck with a manual transmission.
Any idea what I may have effed up? I know some of the throttle body cleaner probably got pretty deep into the TB. Also, there was a lot of gunk inside the TB that I could not get to as it was too far back to reach. The MAF cleaning seemed to go perfectly, I sprayed off the sensor wire and the iside of the tubing then wiped dirt off the screen with a clean rag. It all looked sparkly new and perfect afterwards. Any idea what I may have effed up?
Might have fouled your plugs from too much cleaner. Pull em and check.
Personally I wouldnt dare spray anything on the maf sensor. That baby is really senative and to go spraying anything on there is risky business regardless of how many people say they "do it all the time with no problem"
-matt
-matt
well your first problem was that you used electronic cleaner on the MAF instead of there MAF cleaner. Then you weren't supposed to wipe down the screen or any part of the MAF because it is very sensitive and there cleaner dries up very very very fast for that reason.
Well I just lightly wiped off the screen, didn't damage it at all. And the cleaner says it's for delicate electronic sensors, seemed like the right stuff, there was no specific MAF cleaner at Advance.
lol i always thoughroly (sp?) wipe down the screen and dry the rest with a hair dryer... maybe i got lucky?
i cleaned my maf and ended up buying a new one. never clean a maf with any type of electronic cleaner. its better to replace it!
EDIT: nissan dont recommend cleaning the maf.
I pulled a plug and the white tip and basically all the threads are covered in some sort of black corrosion. Guess I'll be shelling out the cash for a new set. Anyone know the best price for Bosch plats and where to get them?
After researching the Bosch Plats a bit on the web I've heard not so good things about them. Is there any plug you guys would recommend?
I bought a set of the iridiums and put them in. Problem is definitely improved, but there's still major hesitation as soon as it gets above 3000 rpm. The weird part is, if I have it sitting in my driveway in neutral and rev it it'll shoot all the way up to redline, but when I'm actually driving it just dies above 3000. I guess it's the MAF. This is turning out to be a costly mistake
Dont worry everyone makes mistakes, atleast u learn from them
Originally Posted by BlackMaxdout
One wire is insulated, while the other is not, and the MAF throws back voltage signals depending on the temperature difference between the two wires. In theory, the air flow rate is proportional to the difference, since one wire is heated and is cooled by the flowing air. This is also where the air temperature sensor comes into play.
as i said i cleaned my maf and it went bad i installed new one. so you did the same thing. just buy a new maf the problem fixed. make sure you take it to dealer for ECM reprogramming which recommended.
Check your TPS. Same symptoms as with my 300zx a while ago, rough jerking motion. Either the contacts are corroded and loose or your TPS may have FAILED. It was intermittent for a while but after a little bit it wasn't just first or second gear anymore, it started doing that to me on the freeway at 70 mph.
Why would I need the ECU reprogrammed?
and ecm reprogramming brings you better gas mileage plus the new maf benefits.
Update - Got the MAF and installed it tonight. Still have slight hesitation until about 3000 rpm at which point it pulls like a mother. Is it possible that the ecu needs to relearn the fact that it can actually add fuel at lower rpms, or will it have to be reprogrammed? I only ran with the bad sensor for <70 miles.
Originally Posted by OC guy
well on 00+ maxima's it requires ecm reprogramming when the new maf is installed.
mail. dumb question...........changed your air and fuel filters? a bad enough clog in those could cause this.
autozone may have the gaskets, but if not get them from the dealer. not absolutely necessary, but may as well do it right. keep us updated.
I've gone through and cleaned the entire intake assembly from the filter all the way up to the TB. I didn't oil the air filter because of the bad things I've heard. But I doubt it's the fuel filter, there were no problems whatsoever until I messed with the MAF and TB, I doubt it just coincidentally got clogged. If I clean the TB and IACV thoroughly and still have the problem I guess that will be my next course of action.
litch
123
Jan 4, 2024 07:01 PM
