Some engine help please
Old Dec 5, 2006 | 03:32 PM
Blain's Avatar
I changed my bosch platinums to NGKs over the weekeend and it started up fine.
Didnt drive it till today and the engine wont go over 2000 rpms without sputtering real bad and it won't go over like 50 mph.
Only thing i remember it maybe leaning on coil unit while it out, it didnt break but i heard a crack noise.
I got the plugs as close to .044 as i could, some may be under if anything.
HELP!
Old Dec 5, 2006 | 04:13 PM
2da mizzax's Avatar
it probably broke. any CEL?
Old Dec 5, 2006 | 04:45 PM
PLUMMAXSE's Avatar
Just pull the coil out while the engine is running. If its good the engine will stumble. If bad the engine won't change idle and thats your bad coil. The cel(from pulling the coil) will clear after a few days.
Old Dec 5, 2006 | 05:16 PM
MDeezy's Avatar
sounds like your MAF. Try testing it.
or to really get the ball moving, put the old bosch back in and see if the car still act the same. if not, then dont worry about the sparks, it must be something else.
Old Dec 5, 2006 | 06:02 PM
Blain's Avatar
The individual spark coils?
And whats MAF? sorry and thx!
Old Dec 5, 2006 | 06:57 PM
2da mizzax's Avatar
MAF = Mass Air Flow (sensor) which probably isnt the issue since you didnt touch it (i assume). Plum had the perfect suggestion. If you remember which one you may have cracked unplug it while running. if you dont rememebr do them 1 by 1. you can always reset the ECU after you are done if it isnt the coil pack.
Old Dec 5, 2006 | 07:05 PM
99se5speed's Avatar
SHIFT_up
Usually the MAF is what restricts your engine from going over a certain RPM. If you search that's what will come up.
Old Dec 5, 2006 | 08:45 PM
Blain's Avatar
I unplugged all while running, each time a slight increase in idle, thats why im posting thought it would be very obvious if i screwed something up.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
