Normal or bizarre? Revs increase when steering wheel is turned
Old Dec 7, 2006 | 06:00 AM
dr-rjp's Avatar
Lately, I've noticed that when I turn my wheels while stopped, the engine revs, like from 750 to 1,100RPMs.
Why does it do that?
Old Dec 7, 2006 | 06:11 AM
Dubbya's Avatar
VK56 Inside
The power steering pump does that.
Old Dec 7, 2006 | 06:12 AM
Wassup2114's Avatar
Because it takes a ton of power to overcome the static friction that tires have (w00t physics) when 3000 pounds of metal is pushing them against the ground.
Old Dec 7, 2006 | 11:00 AM
99se5speed's Avatar
SHIFT_up
normally i would say this is perfectly normal, BUT 1100rpm WTF!? It's only supposed to increase the rpms by maybe 100-200rpms at most.
Old Dec 7, 2006 | 11:09 AM
dr-rjp's Avatar
I should add that the surge only occurs when the wheel comes almost to the end of the turning circle on either side.
Old Dec 7, 2006 | 11:15 AM
99se5speed's Avatar
SHIFT_up
lol you should have started of with that...TOTALLY NORMAL! Technically this should happen on every single car with power steering.
Old Dec 7, 2006 | 04:56 PM
96i30azn's Avatar
Thats bad physics because it's still static friction when the car's rollin. Only in a skid does it become kenetic friction, still static friction of rubber on pavement is 1.0 and kenetic is .9.. not much difference. Also it's only 60% of that 3100 lbs. on the front wheels.
Old Dec 7, 2006 | 05:00 PM
nismology's Avatar
It's actually the IACV that does it to compensate for the higher load on the power steering pump.
Old Dec 7, 2006 | 05:14 PM
Wassup2114's Avatar
Well I never got very good grades in physics.
Old Dec 7, 2006 | 08:56 PM
gmax96's Avatar
totally NORMAL cuz if it doesnt ur motor is gonna stall. PERIOD
Old Dec 7, 2006 | 09:07 PM
nismology's Avatar
Not quite. The motor won't necessarily stall, but the revs will drop.
Old Dec 7, 2006 | 09:09 PM
tbergma1's Avatar
nismology nailed it..... same thing kinda happens when you turn on your ac
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 11, 2015 12:53 PM
