xdrill/slotted rotor
Old Dec 7, 2006 | 07:41 PM
jian622's Avatar
any good recommendation on on break pad for xdrill/slotted rotors with PRB Metal Master pads,,,,its been 4 month and the pads are down to about 60% now....any better pads that lastes longer than the PBR Metal Masters?
Old Dec 7, 2006 | 09:10 PM
AxisKill's Avatar
Hope this helps -
http://forums.nycmaximas.org/showthread.php?t=14201
had my final decision since september 1st... still running with no complaints
http://forums.maxima.org/showthread....422679&page=10
check if deal still open.. tell them AxisKill reccomended them myb i'll get a bigger discount next time
Old Dec 7, 2006 | 10:43 PM
FantasyGod's Avatar
I find it ironic that you are placing much of the weight in decision making on pad life yet you wish to run slotted and cross-drilled rotors. Cross-drilled rotors are not typically resurfaceable and are usually replaced when warpage or cracks appear. Also cross-drilled rotors tend to crack at the holes, BUT brake systems that were designed to incorporate cross-drilled rotors are usually increased in rotor thickness to compensate. I'm quite sure that your setup was not developed with cross-drilled rotors in mind and hence the greatly increased risk of your rotors cracking. Also some other factors when considering brake pads, such as pad friction coefficient (stopping power), pad dust, pad noise, pad fade, price, etc...
To answer your question, OE pads have excellent life.
FYI, you should know how a cheese grater works, now imagine you have cheese graters at all 4 wheels and that you are deciding what kind of cheese that you should buy for increased durability.
Old Dec 8, 2006 | 12:49 AM
96blkonblkse's Avatar
Ive had my cross drilled rotors on for about 2 years, no signs of cracking, i check them regularly because of the fact that there prone to cracking. I highly reccomend the hawk hps pad. The only downside is the price and they dust a lot
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
