DIY question clutch pedal
Has anybody ever changed that little switch on the clutch pedal...
clutch interlock switch? by themsleves...?
Is there a write up on that?
Is it hard to do?
Basically, When I start the car, there would be hesitation and I would have to play with the clutch pedal in order to get contact.
So, I asked around and people said either ignition switch or that clutch interlock switch or both.
Just changed the ignition switch and it solved half of the problem...
I still have to play with the pedal in order to get the damn thing to engage...
Please help.
thanks
Is it hard to do?
Please help.
thanks
Originally Posted by pmohr
Hook the two wires up to eachother (in the harness to the clutch interlock switch). Of course, then you won't have cruise control...
Originally Posted by Vlasic
I have my switch bypassed and I still have cruise control.....
THere are two switches, one is on top of the clutch pedal , that is for cruise control, and the other switch is for the starter, its on the bottom of the pedal, what you need to do is get to the one on the bottom and hook the two wires together.
... hmm why not just replace the switch... nice to know your car wont jump up and all over the place... if you forget to press teh clutch.. but hten again... you shouldnt have a manual if you forget things like that...
but never the less.. its a good feature to have.. incase you pas. thinks its cold in teh car.. and wants to start it...
buy a wire tap... at the local automotive store... go underneith the pedal and right behind the button tap the two wires together.. or just slice the connector and electric tape the wires together. I sugest using a wire tap cus you could always take it off.
03-12-2020 12:06 AM
