Why is my clutch whinning?
Old Dec 11, 2006 | 08:42 AM
99se5speed's Avatar
SHIFT_up
Ever since it's gotten fairly cold outside i've been getting a strange whinning sound when engaging 1st gear or reverse. This is only in those 2 gears and only when engaging.
2nd, 3rd, 4th, 5th gears are fine and don't make a single sound. The sound isn't always there but 80% of the time. If i hold the clutch a little longer after it catches (different situations require different methods of driving in NY) it'll make the sound. Meaning if i "burn" the clutch for like an extra 5 seconds you'll hear the whine very distinctly.
When i reverse it'll make the sound. Everytime i try and mimic the sound the my Mechanic i can't, i always seem to drive super perfectly when trying to show the problem (i hate when that **** happenes). I replaced my Clutch with a 5th gen clutch, TOB, PP and put in a SS clutch line, and for the love of anything good i can't pinpoint the problem.
Theres no sound with the clutch engaged or w/o out. It only happenes when catching 1st and reverse. This is really bothering me. What can this be? I don't even have 10k on the new clutch, I babied it for awhile before i went WOT, it doesn't slip, i never smell burnt clutch, the fluid in the Tranny is Amsoil 75w90. I checked and the fluid is up to the Max line and nothing seems to be leaking. I also changed my rear main seal along with everything and every oil seal associated with motor and tranny. I'm stomped! HELP!
Old Dec 11, 2006 | 11:08 AM
99se5speed's Avatar
SHIFT_up
bump...anyone? I'd like to pinpoint the problem and fix it before it leads to something major.
Old Dec 11, 2006 | 01:22 PM
marky339's Avatar
bump cuz i have the same thing going on, except i thought it's normal, especially for the reverse gear, was a lil surprised it made the same sound for 1st...
edit: I also have a 99 se 5spd
Old Dec 11, 2006 | 03:11 PM
ukraini9mofo's Avatar
its the clutch throwout bearing
Old Dec 11, 2006 | 05:42 PM
99se5speed's Avatar
SHIFT_up
it's brand new and it's the 5th gen one. also i thought the t/o made noise when the clutch isn't engaged or was it while engaging...lol anyway it's brand new...
Old Jan 3, 2007 | 08:00 AM
momay's Avatar
bump: having the same problem?though on the service manual it indicates worn or damaged t/o bearing for clutch noise.
Old Jan 3, 2007 | 08:41 AM
ComradeJew's Avatar
clutch throwout bearing makes a funny noise when you engage and disengage clutch, not when you change gears right?
Old Jan 3, 2007 | 09:49 AM
shilov's Avatar
I had this whine before I put a new clutch kit it in a month ago. Someone told be that it was because the clutch plates had got glazed from overheating and its not a big deal as long as it it's not slipping. I think I did overheat it a couple of times trying to lounch with a hand break ingaged. It was my first manual car.
Old Jan 3, 2007 | 09:56 AM
MDeezy's Avatar
I had a bad whine in 1st gear, and some in reverse. my input shaft bearing was going out, plus my input shaft was grinding, I had really loud whining in 1st. no so much in 2nd. a new tranny was needed.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
