y pipe question
Old Dec 11, 2006 | 10:25 PM
mastercater7's Avatar
VQ35 FTW
y pipe question
so i installed my budget y pipe today and had a few questions. is it normal to sound all bee buzzing with a stock exhaust? also it backfires is that ok? and will a catback eliminate that bee sound?
Old Dec 12, 2006 | 12:41 AM
LiGhtSoUt's Avatar
the bee sound is the bees in acan some people get it some dont
Old Dec 12, 2006 | 06:52 AM
nexgenmax's Avatar
R34
Catback will not eliminate this since the bees in the can noise it's located at the y pipe itself, which at the front of the cat. correct me if i'm wrong.
Old Dec 12, 2006 | 07:13 AM
matty's Avatar
The bees in the can sound you hear is the air going by the flex section inside the y-pipe. The only way to eliminate that is to get a "lined" flex section made and put in, or replace the Y-Pipe. My old one had that sound and I was soo fed up with it, so I got an entirely new y-pipe
-matt
Old Dec 12, 2006 | 07:25 AM
MaximaSE96's Avatar
Maxima Owner
Just wrap it with hi-temp exhaust wrap....are u running any other exhaust mods than just the y-pipe
Old Dec 12, 2006 | 07:31 AM
Gismo-T's Avatar
B!tch We Got a Problem
Make sure your flex section is straight, & there are no bends in it!
Had the same problem, but not anymore.
Old Dec 12, 2006 | 09:41 AM
f550maranello2's Avatar
its the ghetto *** flex section OR.. the y pipe isnt tigh enough OR the gasket is bad.......
but yea after u check all those get some exhaust rap...
Old Dec 12, 2006 | 10:28 AM
x X CLoud X x's Avatar
so Exhaust wrap is the answer to getting rid of these noises?
Old Dec 12, 2006 | 11:45 AM
Gismo-T's Avatar
Nothing ghetto about the flex section...it's a lined flex section...not like the old ones...make sure all your gaskets are new, and like I stated before, make sure it's supported by a hanger or something so it doesn't hang down.
Old Dec 12, 2006 | 12:06 PM
MaximaSE96's Avatar
Maxima Owner
it will help with the noise...making it not as noticeable if at all
Old Dec 12, 2006 | 12:48 PM
VQ35 FTW
hmmm mk well theres no leaks at all thats for sure, so im sure its tight on there. wot i can hear it rattle in 2nd gear. its just kind of annoying. its the first peice of the exhaust ive changed everything else is stock. where can i get exhaust wrap and for how much. thanks
Old Dec 12, 2006 | 01:05 PM
MaximaSE96's Avatar
Maxima Owner
choose ur poison
http://www.jegs.com/webapp/wcs/store...13943_-1_10261
Old Dec 12, 2006 | 01:12 PM
Gismo-T's Avatar
Could also be your heat shield rattling...make sure nothing is rubbing against the y...
Old Dec 12, 2006 | 01:32 PM
Maxgig's Avatar
make sure they used new bolts on the connections as well
Old Dec 12, 2006 | 02:46 PM
VQ35 FTW
well looks like i have an exhaust leak. it sounds really terrible wot. dammit.
Old Dec 12, 2006 | 08:10 PM
it is a crappy flex section.. my warpspeed is a pos and is LOUD.... catman for the win...
Old Dec 12, 2006 | 11:00 PM
96blkonblkse's Avatar
ive had no problems with my warpspeed. damn f550maranello2 were always conflicting...dynomax...warpspeed..what else hahha. I think y-pipes seem to be hit or miss with bees in the can noise/ build quality. My warpspeed unit was welll built, ive had no problems with it.
Old Dec 12, 2006 | 11:30 PM
werd lol... confliction is bad... ur right though... it is a hit or miss with the
y pipe... my friend has one from warpspeed as well and t doesnt sound like mine does...
Old Dec 13, 2006 | 06:25 AM
scrhale's Avatar
The backfiring is from the car running rich. Correct if I am wrong, but that is most likely because you have a decent leak coming off of the exhaust manifold. The air escapes, thus not hitting the O2 sensor which in turn informs the car to run more rich to compensate. Make sure they actually installed the new crush gaskets.
Old Dec 13, 2006 | 06:39 AM
2da mizzax's Avatar
is the stillen any quieter?
Old Dec 13, 2006 | 07:39 AM
how much are they charging you to install the Ypipe?
Old Dec 13, 2006 | 12:55 PM
VQ35 FTW
i was doing it myself and it was leaking, so i jacked it up last night and tried to get a nut off and guess what? it pulled my hole ****ing bolt from my manifold off. so i had to tow it to a shop. pretty sweet.
Old Dec 13, 2006 | 09:57 PM
VQ35 FTW
have to wait another two days for nuts and gaskets to come in. the ones budget sent me were smashed... and i have to drive like a grandma cuz if i give it just a lil too much, it sounds like my car is going to fall apart. on top of that, its cold here and i have to drive with windows down cuz the exhaust leaks before my cat and into my car. anyone else have installation problems with their budget?
Old Dec 13, 2006 | 09:59 PM
VQ35 FTW
and how far down should i heat wrap my y pipe?
shilov
Feb 19, 2024 09:40 PM
lrb6805
Sep 17, 2015 04:49 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Violator
Sep 9, 2015 10:14 AM
