Clutch recommendations
Old Dec 12, 2006 | 07:53 AM
Swazey's Avatar
i need to replace my clutch badly. i can no longer stand slippage over acceleration. just curious to know what you guys would recommend for a clutch. i do not want anything too crazy like a stage 2 or stage 3 racing as i have to need for that setup. i do have headers, y-pipe, high flow cat, and cat back. should i stick with stock? 5th gen? any recommendations? and also where would be the best place to get the clutch? i will be doing install myself
Old Dec 12, 2006 | 08:25 AM
99se5speed's Avatar
SHIFT_up
5th gen clutch, PP, TOB, and SS clutch line. Much better over stock and will work perfectly with your set-up. Plus the clutch is a known name brand, made by Exedy and it's the same as the Exedy Stage 1 clutch.
Old Dec 12, 2006 | 08:27 AM
MaximaSE96's Avatar
Maxima Owner
and the pressure plate is used in stock JDM s15 silvias
Old Dec 12, 2006 | 08:50 AM
99se5speed's Avatar
SHIFT_up
no ****, that's a pretty good fact to know...
Old Dec 12, 2006 | 08:54 AM
Capital15's Avatar
Where is the cheapest place to get a 5th gen clutch at?
Old Dec 12, 2006 | 08:58 AM
99se5speed's Avatar
SHIFT_up
well ComradeJew bought his online from various parts stores, i went straight to the stealership and bought everything for under 200 (friend works for nissan)
MaximaSE96's Avatar
Maxima Owner
the dealer parts are actually quite reasonably priced...its ur best bet for Genuine Quality parts
http://www.courtesyparts.com/Merchan...Category_Code=
Old Dec 12, 2006 | 10:32 AM
99se5speed's Avatar
SHIFT_up
make sure it's genuine and not key value. It should say Made in Japan and Exedy on it.
Old Dec 12, 2006 | 08:45 PM
Swazey's Avatar
thanks for the input guys. much appreciated
Old Dec 12, 2006 | 08:49 PM
Apparition's Avatar
Ichiban King
5th Gen or ACT Stage 1..
Old Dec 12, 2006 | 09:11 PM
Poowill's Avatar
on 5th gen setup...
Old Dec 13, 2006 | 07:57 AM
x X CLoud X x's Avatar
5th gen clutch, PP, TOB, and SS clutch line, how much does this all come out? and the cheapest would be to buy from ^ that website provided in post#7
Old Dec 13, 2006 | 09:56 AM
ffcbairn's Avatar
Not sure with the clutch line as I didn't do that but when I got my 5thgen clutch, pp, and tob it came to a little under 200.
Also, I don't know if you change your tranny fluid yourself but if you don't or haven't you will need to get tranny oil, specifically GL-4 tranny oil which seems to very rarely be available in stores so you will probably have to order it.
I bought Redline MT-90 from myoilshop.com
Old Dec 20, 2006 | 04:03 PM
Swazey's Avatar
im gonna go exedy stage 1 kit. found one online for under $220. ill have it in a few weeks when i get back from miami. ill let you guys know how it all goes. thanks again!!
Old Dec 31, 2006 | 08:34 PM
toddemullins's Avatar
Two questions:
1. 99SE5Speed, where are you getting your information about the 5th gen OEM clutch being the same as the Exedy Stage 1? My research shows the pressure plate clamping force to be different.
2. Swazey, where'd you find it for $220?
user 11122324
42
Jul 18, 2022 03:35 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
carlosvq30
Sep 26, 2015 09:44 AM
sdotcarter
Sep 2, 2015 09:53 PM
